Westle's Suspension Thread
Westy Mar 24, 2011
  1. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Mine dont look like that I dont think, I'll Check at lunch.
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    Cheers Dane. I'll be swapping them over next week if they are upside down. Should the slack be on the top like mine or the bottom :think:
  3. Dane
    4,086
    182
    Having said that you might have an extra coil than mine, Ill take a picture if I can.
  4. Westy
    17,443
    1,103
    Cheers Dane, I need to put my mind at rest because I'm scared of snaping a spring now.
  5. steve bain
    steve bain Member
    642
    always try turning it off and on again before anything else...
    can't see which way up the coils are would make a difference really imo. i would have done them the other way mind...
  6. Dane
    4,086
    182
    Heres my one of my rear springs
  7. Dane
    4,086
    182
    If I remember my rear springs were symmetrical when they were in the box, yours look different as if they might have a correct orienatation
  8. Westy
    17,443
    1,103
    I've emailed Damien at DPM to see if he has any idea.
  9. Westy
    17,443
    1,103
    Just got this reply from Damien:
    Morning,
    The springs being compressed isn't a problem but the springs need to be the other way with the part number reading correct.
    Damian @ DPM Performance
  10. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Aww thats just what i said about the spring and part number lol.
    Looks like you have another late night job for yourself lol.
  11. Westy
    17,443
    1,103
    Yep I'll be doing this in the week next week at some point, PITA!
  12. S3 Nattie
    1,599
    lol its only one bolt to remove once the wheel is off to get the springs out, you will fly through it now you done it before.
    At least you have peace of mind now.
  13. Westy
    17,443
    1,103
    I flipped the springs over last night but nearly ended up cross threading the lower shock bolts that go through the drop link, shock, then into the hub! Got a bit hairy at one point but managed to get them in striaght after greasing them up and persuading them in straight.
  14. Dane
    4,086
    182
    Good work! does it feel any different?
  15. Westy
    17,443
    1,103
    Nope not at all!
  16. Westy
    17,443
    1,103
    She's starting to sit down nicely but the front still looks a bit higher than the rear and it's meant to be 5mm lower!
    Few pics for you as I gave her a quick wash earlier:
