Werkstat Acrylic Prime Application with DA - Best Way?
Ian W Aug 20, 2010
  1. Ian W
    Ian W Active Member
    1,058
    12
    I've been using Acrylic Prime for a couple of years now and always applied and removed by hand but I have a DA now so I wouldn't mind using that.
    What is the process with a DA.
    Do I still apply is by hand then use the DA to remove - what speed should I be doing this at?
    Or
    Do I apply it via the DA?
  2. Jimmeh
    Jimmeh Active Member
    1,438
    I'd always apply by DA - a more consistent coverage and it's easier than burning your shoulder muscles! :p
    I had pretty good results on a light blue E-Class Merc last year sometime by using Prime with the DA on a polishing pad. Spread at low speads and then worked for a little while at Speed 5. Residues removed by hand with a clean MF and job's a good'en!
  3. Ian W
    Ian W Active Member
    1,058
    12
    Cheers mate, just hope the weather holds up.
