were to buy vagcom from ?
jonno123 Apr 22, 2013
  1. jonno123
    jonno123 Member
    99
    hi all as above i need vag com to switch off air bag light , were can i buy it ive seen pepole on ebay selling a copy of vag com and a lead will this work ?
    i need links if possible ,
    or if any one in norfolk with vag com want to earn some pennys let me know
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Genden is the place to buy mate :)
  3. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,120
    353
    Nhn on here sells it
  4. jonno123
    jonno123 Member
    99
    £263 omg !
  5. JudderMan
    JudderMan Well-Known Member
    1,004
    164
    I have the eBay cable and it just tells you what codes there are (and not all), which is still handy. I have a mate with a generic OBD2 machine which was £30 and that clears codes but doesn't tell you of all the Vagcom codes. Still, it's f88k loads cheaper than buying the real deal. My car was a grand so paying a 1/4 again on Vagcom doesn't make sense.
  6. phil miller
    1,211
    166
    you wont find anyother software for that money, bear in mind a snap on veros starts at £6500 and it wont do everything VCDS does
  7. <tuffty/>
    20,892
    3,701
    Stickies!!!!
  8. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,814
    193
    Iirc cheapo cables won't turn off airbags lights, where are you based? Maybe a local user can do it for you? Try vids section user map or even eBay for vids services
  9. Danno57
    Danno57 Member VCDS Map User
    44
    Have you fixed the airbag problem first?
    VCDS won't turn the light off unless its fixed, I'm guessing you're using it to diagnose the fault and clear the code?
    I got mine from an online shop in the uk called Gendan.
  10. <tuffty/>
    20,892
    3,701
    cheap ebay cables and a registered version of VCDS lite will give full functionality.... the question to ask is are you trying to clear a fault or code the airbag light out as these are different things...
    Registered version of VCDS will do both of these things..
  11. jojo
    28,846
    3,509
  12. jonno123
    jonno123 Member
    99
    theres no problem , ive fitted a aftermarket sterring wheel so theres no air bag , and it comes with a resistor to put in line so the air bag light goes off but the fault code is still in the air bag ecu so needs clearing
  13. Tooks
    Tooks Active Member
    753
    29
    Im in Norfolk a fair bit, and would be happy to hook mine up. Depends where in Norfolk you are though?
  14. jonno123
    jonno123 Member
    99
    Hi tooks im about 8 mile from kingslynn
  15. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Im in Loddon 10 miles East of Norwich if thats any help? have vcds pro
