Went to view an A3 S-Line.....
Dan_Sykes May 7, 2012
  1. Dan_Sykes
    Dan_Sykes New Member
    23
    Hi all,
    I went to view a Black A3 3 door S-Line 2.0 TDI 170 yesterday, it was fully specced up with Sat nav, full leather, multi-function steering wheel etc. but it had a couple of issues, one being that the boot had water in it, under the lift up carpet, it hadn't gone into the spare wheel well but was all around the top of it. There were no obvious signs of where the water had got in there but it was a little worrying. Is there a common fault on A3s where water gets in? The other issue was that the drivers door had a squeak when driving along normally as if it was moving up and down against the seals. Other than that it was a beautiful car. I've had a look around and finding a fully specced car like this is very difficult. I've found similar cars but without the sat nav, do these cars still have the nice sounding speaker system? It sounded as if it had a subwoofer?
    Looking on the net I've found a couple of places that retro-fit new sat nav systems to the cars, if I went down this path would the directions appear on the dash computer and would the multi-function steering wheel work with it? Sorry for all the questions but this will be my first Audi and I'd like it to be perfect :)
    Dan
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,420
    9,422
    ​Hi Dan, welcome to ASN. Have a read in the faqs threads at the top of this section, it may answer some of your questions. Hope you enjoy the forum :)
    mozza1202 likes this.
  3. VAG-Slag
    VAG-Slag Well-Known Member
    1,752
    400
    i assume it was an 8p A3 you went to see then? . . You may have more luck posting in the 8p section
  4. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    The water could be due to the common problem of the washer for the rear wiper leaking, mine leaks too. It's a new wiper motor I think about 130 quid. I think most of them suffer from this..
  5. Ash187
    7,478
    735
    So sat navs (RNSE) and the mfsw can be retrofitted and are fairly easy to do. The RNSE is expensive (about 500+) so bare that in mind.
    also the subwoofer you heard is probable a car that had the bose sound system installed so if you liked that then keep a look out for a car that has that. You will know if it has Bose as the front door speaker grills will have the Bose logo on it.
  6. mike170177
    mike170177 New Member
    12
  7. Minstadave
    Minstadave Member
    560
    19
    The stock audio setup has a sub too (apart from the boggo SE model with the basic 2 speaker jobby).
  8. Ash187
    7,478
    735
    the sub on the stock system is really **** and doesnt have a good enough thud on bass. then again the bose isnt that much better but still an improvement
  9. N8
    17,163
    718
    It's a bargain as it's £2200 iirc new/from audi.
  10. Ash187
    7,478
    735
    tis true that! but i prefer the Pioneer units with their new line up of App radio systems :)
  11. c_w
    c_w Well-Known Member
    1,163
    87
    Are you sure it was the door? My 3dr window creaked when it was fully up, but if you flicked the window switch to remove the "pressure" off it (without dropping it) it stopped.
  12. audicruiser
    audicruiser Audi Heaven
    1,865
    Replaced mine last week, £106 all in from Audi.
  13. Minstadave
    Minstadave Member
    560
    19
    Including fitting? Sounds cheap if it did.
  14. Dan_Sykes
    23
    Thanks for all the replies, it didn't have a BOSE system in it but in the A3 brochure it says that if you have the Sat Nav you can't have BOSE, is this true?! Also I can't put my private plate on the car that I viewed as it was 6 months too old :( Finding another in black with all the extras ticked is like finding a needle in a haystack :( I'd go to an S3 but 22MPG is a BIG no no. How often does an S-Line fully specced crop up? I had a look in a 2007 A4 S-line but the interior doesn't feel as special as the A3 and the rear legroom was shocking! With the seat fully back there was about 2" of space!! There was MUCH more in the A3.
  15. lgooch
    lgooch Well-Known Member VCDS Map User
    1,111
    140
    What's wrong with a fully loaded sport ? Just change the wheels and the car will be virtually the same. I know mine is
  16. Dan_Sykes
    23
    Thanks! I'll take a look :)
  17. OVRA3
    1,079
    80
    None of the guys on here worry about spec to much they just spec up themselves afterwards... Some great stuff on here and I am sure you would get loads of help getting the car just how you want it!
