Weitec allen key
Scott Dec 23, 2009
  1. Scott
    Scott Well-Known Member
    1,306
    126
    Anyone with Weitec coilovers know what size allen key I need to adjust the front height?
    Scott
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Do you not need a C spanner?
  3. smudge_don
    smudge_don Active Member
    2,944
    That's what i thought, should have a C spanner that came with the coilovers Scott
  4. Scott
    1,306
    126
    I have 2 C spanners but I was under the impression the height is locked using an allen key with these coilovers - I wouldn't know for sure as I didn't fit them and I had them adjusted at a garage last week (needs to go a bit higher- rubbing with spacers), but I'm not too busy at work and thought I could do it in the underground car park tomorrow where it will be a decent temperature lol.
  5. smudge_don
    2,944
    Pretty sure the C spanner does it :)
  6. V6Pete
    1,491
    Ok yes the bottom ring should have an allen bolt through it. Not sure what size though, sorry. Was just checking you had the spanners also!!
  7. Scott
    1,306
    126
    Thanks guys.
    Anyone have any idea then?
  8. j1mbo
    j1mbo New Member
    21
    hi m8 if its the same as the ones i had on my ibiza it was a 3mm or 4mm i think.
  9. j1mbo
    j1mbo New Member
    21
    o yea if u have the damper adjustable ones its the same as the one on top of the coilovers to adjust damper
  10. Scott
    1,306
    126
    Thanks mate, I never did get around to doing this but will bare that in mind when I get a chance. :)
  11. chris1988brown
    chris1988brown Member
    575
    not rly sure on the allen size m8, but how do you find the weitec's for performance and handeling as im looking at gettin some in the next few weeks and input will be great,
    cheers chris
  12. Scott
    1,306
    126
    Can't fault them mate, haven't really experienced any other coilovers but definately an improvement over stock springs, I also fitted Eibach ARBs at the same time. Ride isn't harsh and not a lot " bumpier " (for lack of a better word) than oem, but car feels much more planted - honestly can't fault them, build quality seems top notch too! One thing I would say is the rear doesn't go very low compared to the front, but it's a good height for me and I've set the front to match. :icon_thumright:
  13. chris1988brown
    575
    awsome cheers mate, very help full, could you stick a pic of your car up showing how ur's is set? cheers chris
  14. j1mbo
    j1mbo New Member
    21
    no probs happy to help. the 1 thing i did find with the weitecs was they are only locked by a grub screw which screws into plastic it is very very easy to overtighten so be carefull bud.
  15. Scott
    1,306
    126
    Will do dude tomorrow if I remember, you'll have to excuse how dirty the car is though, unless the weather improves and I managed to give it a wash.
    Thanks man will also bear that in mind, hope the garage that fitted & garage that adjusted later didn't overtighten then!!! eek!
  16. chris1988brown
    575
    awsome cheers mate much appreciated:)
  17. chris1988brown
    575
    any pics for me yet bud?
  18. Scott
    1,306
    126
    Sorry dude it's been too dark, I will get you pics as soon as it's light I promise lol, problem is I leave car at train station 7am, get back 6pm.
    Have a look here though: http://i669.photobucket.com/albums/vv56/scott1andrews/IMG_0269.jpg
    This was before I fitted the spacers. Rear is as low as will go, but sits nicely now the spacers are on, which I'll take a pic of and show you.
    Front was a lot lower than back on this pic, rubbed a little when taking tight turns quick eg. small roundabouts. It would go lower at the front than this. I've raised it up and fitted spacers to the front too, doesn't look any higher but sits nicer in the arch as I like the front and rear pretty much even. Still rubbing a bit though, probably worse than before, needs to go a tiny bit higher. Again will get pics of this soon!
    I think it's a nice height, definately a good height if you're planning on 12mm rear spacers as I don't think you could really get away with or want to go much lower. It doesn't look that low in the pic due to the way that the photo is taken, but the car definately looks noticably lower from the back compared to other cars.
  19. chris1988brown
    575
    oh sweet mate that looks great, i'll defo be ordering a set soon, some pics from the side and front would be great if you can bud
    cheers chris
