Weird noise can anyone help:
OVRA3 Jul 15, 2013
  1. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Hi all,
    I seem to have a rotational noise not coming from the wheels it happens at around 25+ mph and gets slightly louder .. It's not loud but its annoying me. It happens in gear out of gear and clutch in or out.. Sounds like its coming from the middle of the cabin? Driveshaft maybe? It's not loud as I said but now I know it's there it's bugging me..
    This is a rubbish thread as I think it could be a multitude of things but wonder if there are any good things to check first. Doesn't happen around corners and seems to change with road surface a little but I don't think it's bearings or the **** noisy runway tyres.. Any pointers would be appreciated..
  2. Stol1975
    Stol1975 Member
    227
    20
    I had a similar knocking and it turned out to be a wheel that was really loose. I had new powder coated alloy and if you don't rub away the powder coat around where the nut sits it can come loose. I was lucky I discovered it in time. I was checking for loose exhausts and all sorts.
  3. OVRA3
    1,079
    80
    Ill check them tomorrow :-/
  4. OVRA3
    1,079
    80
    Had it checked today and its the start of a wheel bearing going drivers side is noisier than the others
