weird MAF issues
JaseS3 Nov 10, 2013
  1. JaseS3
    JaseS3 Member
    Anyone got any ideas on this weirdness!
    Car is an s3 8l (2000) . Decat, 007p, n249 delete and remapped.
    Noticed my maf readings where low on vcds (no codes though) and my mate had a brand new seat altea maf (chinese jobby) to hand so gave it a try and the car ran much better... easy then I thought, I'll grab a new s3 bosch maf job done.
    Before I bought one I tried another mates genuine cupra r maf seems as the engine is the same, logged his on vcds and the maf works fine but when I ran it on mine it drove awful!
    Things I noticed on my car with each maf :
    Cupra maf-
    Airflow waaay down to about 150gs (same maf reads about 210 gs on the cupra)
    After 4k the ecu drops requested boost progressively (limp?) but before 4k its fine and fuelling looked ok throughout
    Altea maf (wrong maf!)
    Below 2k its not as smooth but on a run airflow reads about 200gs and it pulls much better 2k upwards without ecu dropping requested boost
    Only thing is the stft goes to about -7 and Itft to about -15!!!
    Why would the car run much better with the wrong maf and fueling out! :-/ anyone?!
  2. jojo
    28,899
    3,553
    Wideband vs Narrow band MAF? there are different MAFs for different versions of the same engine, you just need the correct one!
  3. JaseS3
    JaseS3 Member
    Aha! Thanks JoJo I didn't know that, that makes sense. the only problem is that all the MAF's I'm finding say that they're suitable for all S3 8L's. I don't suppose you know the different part numbers so I can find out which one I need, I'm guessing narrow band for a Wreg (2000)?
  4. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    There is an M part number and E part number. These can also have X after them. IE EX and MX which signifies they are exchange units.
    The M is wideband and E is Narrow band ( APY Engine )
  5. JaseS3
    JaseS3 Member
    Thanks beachbuggy, I'm excited that I might finally get it sorted & hopefully get some power back! :) is TPS the only acceptable place to get a genuine MAF? Seems most posts say stay away from eurocarparts?
