weird electric window issue . . .
deejames Dec 26, 2013
  1. deejames
    deejames Member
    71
    Hi all, i`ve got a weird issue with my front electric windows i did a search but could n`t see anything on here
    Basically i locked the car with the remote, both windows fully up and when i came out the next day both windows were fully open, any ideas?
    the car is a 1998 1.8 Avant B5 with electric windows in the front only
    cheers in advance
  2. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,073
    714
    Does it have comfort close? If you press and hold the close button on the remote with the windows down, do they close?
  3. deejames
    deejames Member
    71
    don`t think so although to be honest i always make sure they`re up before i lock the car
    i will double check and report back
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,967
    2,736
    Thats typically one of the first signs that you have water or damp in the Convenience module.
    The Convenience control module lives under the carpet just in front of the passenger side front seat.
    The pollen filter seal can cause issues and allow water to leak into the footwell. Also check the plenum chamber where the battery is and make sure it's not full of water, If it is the drains under the battery are probably blocked.
    You need to check under the carpet and make sure it's dry. Don't just feel it and assume because it's dry all is ok.
    The insulation is pretty thick and it can be well wet under there but feel dry on top.
    Karl.
  5. Chriscooke
    Chriscooke Clueless!
    512
    25
    I've had a similar issue recently where I came back to my car after a particularly wet night to find my drivers window down and the cabin soaked :(
  6. deejames
    deejames Member
    71
    thanks for the info, my car does n`t seem to have convenience closing but i will check all the above
  7. deejames
    deejames Member
    71
    was it just one window down on yours or both? when it happened to me both went down but my wife told me just the drivers side was down when she came out the gym once but could n`t be sure she had n`t accidentally done it herself
  8. Chriscooke
    512
    25
    It was just the drivers side on mine. It's happened twice now but can't be 100% certain that I didn't hit the button.
