weird buzzing electrical sound when i cancel indicators?
danonline Jun 29, 2010
  1. danonline
    danonline New Member
    21
    Hi all.
    When I cancel the indicators on my a3 tdi 2002, I sometimes get a weird buzzing sound which seems to come from the hazard warning switch? This seems to stop if I put on my hazards but comes back when I put them off.
    Its also not all the time.
    Any ideas?
  2. Imteyaz
    Imteyaz 6th Gear
    535
    Dodgy Hazard switch IMO, I had exactly the same symptoms, a few days later the indicators started to work intermittently. Get a new switch from the stealers (£28), replace switch and your buzzing problem should go away.
    It's a common fault on these cars, along with dodgy temp senders, broken window regulator clips, clutch pedals breaking, vacuum hoses disintegrating........
  3. Purple Princess
    Purple Princess Moderator Staff Member Moderator
    1,044
    ^^^^ yup I had the same. It's a very easy fix :) good luck
  4. Nilz
    11,335
    881
    Mine does this as well, but only since I changed the relay to a new one...strange, I'll just keep an eye on it and see how it goes.
  5. devan
    devan Member
    119
    I also had this, but it seems to have stopped doing it now since i had Cruise Control installed... maybe it was to do with the indicator stalk in my case??
  6. ianysm
    ianysm Active Member
    1,002
    I think it only happens if you've not quite fully cancelled (i.e the switch is half way).
