weekend of achievement!
jcb Sep 23, 2009
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    had a long weekend and actually managed to get some time to myself...and more importantly my motor!
    hoping to update my build thread (which has been particularly slow!) when I get some news from my engine builder tomorrow. woeful attempt to do it myself, too much on and not time (not to mention lack of skill) so I boxed it all up and dropped it off at Engine Services. will be back in a couple of weeks hopefully
    but it in the meantime i have done some sorely needed cosmetic and structural stuff.
    1st up. annoying clunk from the rear when booting it. was convinced something was moving around so bought some shiny bits from 034.
    culprit was rear diff support bracket and bush.
    surprisingly easy job and instant noise removal. feels a bit less sloppy when flooring it after each gear change.
    Old: easily moved around soft bush
    Shiny New one from Apikol...solid:
    In situ:
    Next...front bumper which I have been putting off for 4 months:
    used to look like this:
    I cut the middle spars out of the S4 bumper but never got round to fitting all the modded grills back in.
    middle grill was sitting on my desk for ages, intercooler was not low enough to refit fogs and a bit shiny for my liking!
    before:
    half way:[​IMG]
    light coat of matt black on anything shiny
    Stealthy result:[​IMG]
    just need to finish the holes off left where the middle spars were chopped out six months ago!! bumpers getting a respray in a couple of montsh anyway.
    very pleased with myself, first time I have had the bumper off without breaking something! much easier on an S4 as you can reach in from the front grill and prise the side clips off without bending anything.
    just need to get this never ending engine build and turbo fitted!
  2. Lee Goodall
    Lee Goodall Active Member
    2,279
    Looking good mate :icon_thumright:
    Chop chop.. get that engine in!
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    was that bush expensive?
    you got any more pics of your car
  4. docurley
    4,070
    85
    JCB you should have asked me for some mesh as I have some better looking gear.
  5. jcb
    4,132
    13
    you saying it looks sh1te?! ;)
    got that lot for free. easily replaced if some nice doner steps up with some wider stuff.
    I actually quite like it is it is plastic coated metal and easily bent back into shape when things hit it...as they do quite often!
    Olds: I forget the exact figure for the bush which probably means it was more than I have convinced myself it was! $180 seems to ring a bell. very nice bit of kit, totally over enginered and too shiny for its purpose.
    Am going to rebuild the old one with some solid polyurethane if you want to take that off my hands when done. have found a nice source of 90 grade poly for the job
  6. olds_kool
    1,089
    13
    id be very interested, have you got liquid poly or a solid piece? or id be interested as it is to fill myself, im back down to 2 cars and the stuff ive got takes a week to fully harden
    $180, looks quality but couldnt justify that
  7. jcb
    4,132
    13
    I haven't had a proper look at it yet, need to get the wife out the house so I can get it in the dishwasher to clean it up!!
    probably a solid lump as I am looking at mocking up some inserts for OEM peices otherwise two part poly resin mix in liquid form
  8. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I am jealous of that rear diff mount!
    Did you get any other 034 bits?
    Cooler looks a lot better black too!
  9. jcb
    4,132
    13
    rear sub frame mounts, front snub, engine mounts and gearbox mounts.
    rest going in when I pull the engine hopefully end of the month.
    discovered the rear diff seals are shot too....luckily they were coming out anyway as I bought a Quaife ATB from a guy who had bought the wrong one for his S4 about 9 months ago. 180 brake doesn't justify it.....350 might
  10. PaulJC84
    PaulJC84 Owner
    2,890
    13
    Oh nice, I would like all those parts at some point. What was the cost of all the mounts 034 bits together?
    I dont know where you find these diffs and £100 millteks!
  11. jcb
    4,132
    13
    Ha,
    I got in on the front mount group buy (tried to russle up interest on here but no takers!)
    think it was $350 for snub, engine and transmission mounts.
    Apikol rear was $250 when I checked my email (wish I hadn't now!)
    rear frame bushes were £165 for four.
    plus some shipping.
    he did me a good deal on the label as it read $100 :)
    I get deals like thsoe because I spend waaaaay too much time on the web!
    what I save on parts I lose in lost business!!
  12. PaulJC84
    PaulJC84 Owner
    2,890
    13
    Yeah I remember that group buy. Was tempted by it but I kind of forgot all about it.
    So was about £600 for the lot, quite a bit but should make the car feel a bit nicer.
    I may have to get saving for some of these. Not bought anything for the car in ages.
  13. aragorn
    18,019
    716
    I'd have to wonder how much difference you'd get from poly filling the stock mount compared with that thing you paid $250 for...
    What type of rear subframe bushes did you get? New OE? Poly? Alloy?
  14. jcb
    4,132
    13
    I wouldn't have the underfloor bling factor though would I!
    its an awkward thing to fill, lot of work chopping the centre out to replace it after filling the void.
    Went for Poly rears but am considering the alloy ones as the work in removing OE and replacing ploy is a subframe off job and a bitch at that.
    not looking forward to that one!
    not cheap but I saw the engine nearly jump out of the bay when I had the base dyno done. god knows what the gearbox and subframe ones are like with 100k on them
  15. aragorn
    18,019
    716
    Perhaps pickup a spare subframe and mod that, then just swap it out?
  16. jcb
    4,132
    13
    already looking for one. would like to paint one and fit rather than being off the road for a week! tricky finding B5 quattros in scrappies here. anyone want to sell a rear subframe!
  17. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    mint rs4 back end coplete on pistonheads.
  18. jcb
    4,132
    13
    got a link, I can't find it...
  19. ian52
    1,199
    It's on page 7 in the parts bit.
  20. jcb
    4,132
    13
    £550 is a bit rich for me. final drive won't match so I would have to shift the diff.
    will give him a bell though cheers
  21. ian52
    1,199
    It looks pretty much as new condition but a bit steep.
