Weekend drive comes to a stop!!!! (0) <----- HELP
coopsS3 May 8, 2010
  1. coopsS3
    coopsS3 Woosh Woosh Wah...
    30
    Hi well my cars just had its near side bearing done, its all waxed n shiny ready for the weekend drive 30miles into it A WARNING LIGHT!!! Not happy :(
    So im asking for your help again guys...... (0) <----- the sybmol in amber! is :sorry:in the book but not with an empty circle. Is this simply because the system cant pinpoint a problem so i have a priority 2 problem sumwhere in my ABS/ Breaking system?? i was on the bypass and it came on as i went round the roundabout at about 40, the wheel did clip the drain could this have caused the problem! hope u can help thanks :D
  2. Ian W
    Ian W Active Member
    1,058
    12
    Isn't (0) a brake pad low warning.
    Probably just the wire is damaged if someones had the hub apart.
    Edit - Images
  3. coopsS3
    30
    Brilliant thanks mate just checked my rear pads n there a little low! was worrying was gonna be summit expensive haha thanks again
    Love this website all my troubles get sorted in minutes :D
  4. Ian W
    Ian W Active Member
    1,058
    12
    Rear pads don't have sensors.
    Be the fronts but like I said the wires are pretty weak so may well have just snapped which will bring up the warning.
  5. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Ye it is the brake pad wear sensor. Dont worry though as you have about another 1000 miles before they need changing.
  6. Nilz
    11,329
    876
    As already mentioned, it wont be your back brakes, they dont show up on your dash they will be the front ones that need changing, either that or the wire has snapped.
  7. sportstractor
    sportstractor Chugger
    2,709
    I get warning lights all the time, nothing to panic about.
    You only have a sensor on the passenger side front.
