Website doesn't list 170 BMN
Discussion in 'Revo Technik' started by DarkBunny, Mar 22, 2014.
  1. DarkBunny
    Offline
    DarkBunny Active Member
    Jul 15, 2013
    319
    49
    [Mar 22, 2014]
    Why is this?
    My motor is a 2.0 TDi 170 (57 plate) with the engine code BMN (which I believe to be a PD). Is this not an engine listed?
  2. Ads
    Ads
    [Dec 27, 2014]
  3. Revo Steve-W
    Offline
    Revo Steve-W Active Member
    Jul 11, 2013
    231
    70
    [Mar 24, 2014]
    Hello,
    Unfortunatly this is the one engine that we will not support with software or any products, due to it's well know DPF issues from production.
    We are in the motions of completely updating our website, which should cover off issues such as this.
    The official line would be -
    2.0L PD170 DPF Performance software
    Vehicles affected: 2006-2008 PD170
    Revo do not offer Tuning for this application
    Due to the inherent design limitations of this Engine, the Diesel Particulate Filter and the flawed factory regeneration process, Revo do not offer software for any PD170 DPF application.
    DPF: In simple terms (as VW put it) the Diesel Particulate filter is part of the exhaust system responsible for cleaning the engine exhaust gases before they enter the atmosphere.
    DPF Function and Problems
    The DPF function is to collect soot particles emitted in the exhaust gases. At a predetermined level the DPF supposedly ‘cleans’ itself by a DPF regeneration, a process that increases the temperature with the DPF and burns off the soot particles.
    In theory the vehicle should be able to carry out its regeneration process un-aided under normal driving conditions. However in practice the majority of owners find this isn’t the case and will be told by their main dealer that their driving style is not sufficient for the process to function and that the car needs to then be driven a certain way to clear the DPF. VW group documentation says that ‘short’ or ‘stop/start’ journeys aren’t sufficient and the regeneration process may not complete. We know of customers that have been advised by the VW Group that they do ‘too many motorway miles’ for the regeneration to function correctly.
    VW Group documentation states:
    ‘Driving conditions in inner-city and any UK Island do not proved optimum conditions for the regeneration procedure’
    ‘Consider your driving style and length of journey to allow for the driving conditions required for DPF regeneration’ refer to owners handbook.
    In a lot of scenarios the regeneration procedure doesn’t complete and allows the DPF to further block and require forced regeneration or DPF failure and replacement; something that’s not usually covered under warranty.
    NOTE: the issues with this engine are mainly related to the regeneration process, this process was refined and functions without issue on the PD140 and later CR engines which Revo Fully Support
    Performance software and DPF
    Problems occur when the cars run performance software for the same reasons they occur in standard vehicles, however depending on the driving style these problems can be accentuated when using performance software.
    The DPF can block or get too hot causing hesitation and poor fuel economy. Although Revo haven’t had any dealers or customers experience it, there have been reports in the press of dry DPF systems actually catching fire. Issues experienced are typically erratic power delivery and fluctuating fuel economy.
    For the above reasons and the inconsistency with these engines Revo has decided not to offer software for any PD170 DPF application.
    NOTE: this only effects the PPD170 not other diesel applications that Revo offer software solutions for
    DPF Bypass
    We spent a lot of time looking at potential solutions for this engine, including a DPF bypass solution in the form of an aftermarket downpipe and specific software. We thoroughly tested a DPF bypass setup over an 18 month period before coming to the decision to not support this product.
    NOTE: There are no issues with the PD140 DPF vehicles, or later CR (Common Rail) Engines. Revo fully support these vehicles.
    #2
  4. DarkBunny
    Offline
    Jul 15, 2013
    319
    49
    [Mar 24, 2014]
    But mine doesn't have a DPF Steve...
    #3
  5. RevoKev
    Offline
    RevoKev in the fast lane
    Aug 9, 2005
    152
    [Mar 25, 2014]
    It would have done from new though!
    It's not just the DPF, they have a whole host of issues in standard form. The factory updates reduced overall output by upto 15% from the original factory software for those engines. We stopped supporting these cars when they were still being sold new due to the issues they had then.
    #4
  6. DarkBunny
    Offline
    Jul 15, 2013
    319
    49
    [Mar 25, 2014]
    It didn't though... Checked my codes in the boot and it's a non-DPF version.
    Shame :sob:
    #5
  7. RevoKev
    Offline
    Aug 9, 2005
    152
    [Mar 25, 2014]
    I've never seen a non-DPF PPD170. Regardless they were not good engines for tuning!
    #6
  8. DarkBunny
    Offline
    Jul 15, 2013
    319
    49
    [Mar 25, 2014]
    I could bring it in for you to have a session on :icon_thumright:
    #7
    Sandra likes this.
  9. RevoKev
    Offline
    Aug 9, 2005
    152
    [Mar 26, 2014]
    Thanks but no thanks! :)
    #8
    DarkBunny likes this.
