Weak Front Wiper Motor
Lowride Oct 23, 2011
  1. Lowride
    Lowride Member
    137
    Hi Guys
    I recently purchased new front wiper blades from Halfords as my old ones were worn out. I took one of the old ones in with me to make sure I got the right ones.
    Since fitting the new ones the motor barely moves them across the screen and they often stop half way.
    I ASSUME the wiper motor needs replacing but even the breakers want £70 so thought I would ask around first..
  2. kite
    kite Member VCDS Map User
    677
    the wiper mech. is known to seize up. There might be a sticky on here about replacing or repairing a rusted mech.
  3. yendall24
    yendall24 Member
    571
    9
    hi mate before i started blameing the wiper motor i would look at the spindles that drive the wiper arms . these are notorious for seizing in the carrier due to rust . i had the same happen on my 04 a4 avant i had to strip the wiper machanism out of the car strip it down and clean the spindles with emery cloth and give them a good greasing . do a search for seized wiper arms it is a very common problem
  4. kite
    677
  5. Lowride
    Lowride Member
    137
    many thanks will give it a go!
  6. quattrojames
    14,068
    585
    It's pretty straightforward, the fiddly bit is getting the mechanism out from the bulkhead.
  7. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    And getting the wiper arms off the spindles which can be almost impossible.
  8. Don't try and lever them off like i did as you'll crack the screen!!!
    with lots of plus gas they should wiggle off by holding the arm and moving up and down rather than trying to pull them straight off (if you know what i mean)
