Waterpump: with metal impeller 1.8T
Clach Jul 12, 2007
  1. Clach
    Clach A3 - 1.8Ts
    971
    Hi Folks,
    Does anyone know where I can get a waterpump with a metal impeller for a W reg 2000 1.8T? also a sound dampner for the undercarriage, the dealer quoted £120 for this item :wtf: and no luck on e-bay?
    Thanks again,
    Magic forum this! :applaus:
    Craig
  2. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
  3. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    was the metal impeller standardised accross the range after a certain date ? how would you know if your plastic one is functioning correctly ?
  4. madvw
    madvw Active Member
    2,489
    metal impellers are third party only. Audi still use plastic impellers. Audi changed the design of the plastic ones after they started to fail though, so new plastic ones are supposed to be OK.
    You can tell if its broken, because your car will overheat.
  5. AwesomeSarah
    AwesomeSarah Member
    726
    I have seen the water pumps when they have gone
    It was not the design of the impella`s but the fact that it cracks around the bolt that holds them together
    I would do the metal impella`d one myself and they are only approx £25.00 ish
    Sarah
  6. LaSarthe&Back
    LaSarthe&Back Member
    300
    And this is why.....
  7. Bash_A3
    Bash_A3 Member
    233
    Not all of the ones from GSF are metal, ask on the phone to confirm.
  8. Spacecowboy
    Spacecowboy Member
    367
    Ooof nasty! You can forgive your S3 for overheating if you have the placcy still in!
