I have built a new engine for my car and been looking into it, was for a VW VR6. But i've gone off the idea for a few reasons:
1) Can be flammable if say a pipe bursts and it spills onto a hot exhaust manifold
2) Expensive, You would have to carry some around with you, you can't top up with water in an emergency
3) Been told the proper mix of G13 is fine, (its worked just fine on my car for the last 20yrs)
4) Its doesn't make the engine run cooler and the waterless stuff doesn't transfer heat as well as water. So your cooling system is actually less efficient. Its also thicker than water/coolant mix so more effort to push around the system.
There are some good sides to it, but i ended up reaching the opinion if you have a race car and are having problems it can help the situation, but on a normal road car, stick to coolant/water at the correct ratio. I've got no idea what would happen if your head gasket went and this waterless stuff got into the combustion chamber.
