Water under battery tray & brake master cylinder....
jrleech May 19, 2006
  1. jrleech
    jrleech Member
    40
    I was just washing my car and when I lifted the engine lid I noticed a load of water (about 3 litres!!).
    It was under the battery tray, brake master cylinder and around where the coolant hoses go to the heater matrix (about half an inch deep). Took about half an hour to sponge it all out.
    It's obviously designed to get wet, as the runoff at the bottom of the windscreen dumps the water there. I'm sure it's not designed to stay full though,
    I'm guessing there's a drain hole or two and they're blocked. Does anyone know where they're located??
    Thanks,
    Jon
  2. Rev-head
    Rev-head Active Member
    2,987
    Drain Hole is located on the left hand side of the Battery(looking down) probably blocked
  3. jrleech
    jrleech Member
    40
    Thanks.... I'll have a good hunt around in the morning.
  4. Nessy
    Nessy VW + Audi mad
    876
    74
    There is a drain hole with a big rubber grommet thing located right underneath the battery tray that is meant to act like a sort of primitive one-way drain valve....
    Thing is, it easily gets blocked up with rubbish/slime/crud, once battery and tray are removed its a 2 minute job to remove and clean grommet....did this a few months ago with no probs since.
    /ubbthreads/images/graemlins/wink.gif
  5. jrleech
    jrleech Member
    40
    Nice one, thanks. Hope I can remember my battery code!! It was like a lake in there yesterday!!
