water methanol injection ??
tony696 Feb 2, 2011
  1. tony696
    tony696 Member
    165
    hey,,
    im after abit of info im doingto install my wmi kit but i want to put my tank in the boot what pipe can i use to run from back of car to the front I was thinking if I could use 4mm silicone pipe ??
    and
    where can i buy methanol from in the Birmingham area ?
    Tony
  2. badger5
    9,400
    1,943
    silicon wont hold the pressure.. unless the pump you are using is low pressure one..
    what kit do you have?
  3. tony696
    tony696 Member
    165
    i have the cooling mist one mate it as a high pressure 200-250 psi pump,
    can you supply the pipe ?
    tony
  4. badger5
    9,400
    1,943
    what size connections to the nizzle/pump?
    they are push fit connections usually. plastic/nylon airline small bore type pipes.
    1/4" size on US kits usually.
    silicon vac hose is not going to be correct for this
  5. Jade S3
    Jade S3 270bhp 13.6 1/4 mile
    24
    4mm is too big , use a heat proof pipe. Make sure u buy decent quality meth coz u get cheap 'offcuts' , also increase timing with lemmiwinks. My meth comes in at about 1 bar off boost, the 1.8T's dont like large quantities injected so becareful. It made a HUGE difference! :)
  6. Jade S3
    24
    Wmi reduced my intake temps by 30 degrees! I run 70% meth with 30% water, the nozzle is mounted by the map sensor and the pump is mounted behind the front bumper
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Too much meth there - 50/50 is the max that the cooling mist pumps allow before their internals begin to get eaten by the meth...
  8. Jade S3
    24
    Hey welly judging by your power figures im sure 50/50 works great, will do that from now on. Thanks alot, your car looks epic. Do u have any videos?
  9. Andrew@A.L.D
    3,873
    609
  10. badger5
    9,400
    1,943
    look for your local biodiesel suppliers for virgin grade 99.95% methanol.
    50/50 is max you should mix.. pumps/seals etc not rated more than that
  11. badger5
    9,400
    1,943
    who said 4mm?
  12. JS1500
    JS1500 Howdy
    1,166
    10
    The OP.
  13. tony696
    tony696 Member
    165
    yh it as got the 1/4" pipe with push on connections.. air line pipe as in like air compressor
    thanks
  14. tony696
    tony696 Member
    165
    lol 4mm i know now haha i looked at the wrong pipe lol i think ive sorted the pipe now
    all ready for mapping now :)
    thanks
  15. tony696
    tony696 Member
    165
    me lol i looked at the wrong pipe woops lol think ive sorted the pipe now ive got a local hose specialist around the corner from me :)
  16. Welly
    10,696
    127
    I don't run water meth yet... fitting it next week...
  17. badger5
    9,400
    1,943
    log 020 when playing with it.. (wmi that is :p )
    unisettings to add some timing, in little steps, you dont want to see more than 6CF on block 020
  18. badger5
    9,400
    1,943
    lol... why could'nt I see that... jeez I need glasses
    1/4" is its size tho.. :)
  19. tony696
    tony696 Member
    165
    thanks all
  20. tony696
    tony696 Member
    165
    where is the best place to put the injector in boost pipe ? just before throttle body ?
    thanks
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    No that is to close, anywhere after the IC ,wellys just put his on, look at his thread
  22. Jackal
    Jackal ....minus the bite.
    33
    My friend Bruce owns Methanol-Injection and he would be open for group buys.
    If local he can get it fitted also.
    His demo car is a 550bhp Skyline.
  23. badger5
    9,400
    1,943
    thing is Devils Own have proven to me to be very unreliable controllers and their service backup is deadly slow
  24. Jackal
    33
    Is that through my friends website?
    If it is it surprises me as he is dedicated to his customers.
    Let me know.
  25. badger5
    9,400
    1,943
    he does'nt make devils own, he supplies them.. DO themselves have been dire in turning round their failed controllers... Not your friend.. never dealt with him personally. I'm sure he's fine.
    I think, DO had an issue with their design, as the ones I had fail on several customer cars were all what looks to be a superceeded controller, but my condifence in DO given the hassle it caused me has gone.
    AEM get my business now... and boy thats a decent kit, well price and fully featured out of the box, better engineered imho. I have used Aquamist, Snow Performance, Devils Own, and now AEM... and AEM is the best kit I have yet used.
  26. Jackal
    33
    Fair comment. If you've tried them all................you're in a place to call judgement.
