water methanol injection guys :)
tony696 Mar 15, 2011
  1. tony696
    tony696 Member
    165
    hi all,
    I'm finally getting my wmi set up on my s3 what psi have you guys got the wmi kicking in at and how much timing pull you lot running
    you will have to help me if I'm getting it wrong I'm new to wmi
    any help would be appreciated
    thank Tony:icon_thumright:
  2. superkarl
    superkarl MAN OF STEEL
    9,493
    2,436
    Welly is your man for this! Are these details not in his thread??
  3. tony696
    tony696 Member
    165
    ive not seen them but i now hes only running 22psi i will send him a pm thanks
  4. Westy
    Westy Well-Known Member
    17,443
    1,104
  5. <tuffty/>
    21,354
    3,921
    AEM kits are pretty good... have a decent controller and sizeable tank as std... I have a Devils Own kit to fit in mine... controllers have been an issue in the past which is why Bill has been using the AEM kits recently...
  6. Westy
    17,443
    1,104
  7. <tuffty/>
    21,354
    3,921
    I think thats an earlier kit in the picture as pretty sure all the new stuff has an integrated nozzle/check valve setup and 200psi pump... may be worth confirming that with them before buying...
    AEM Water/Methanol Injection System, Water/Methanol Injection for Turbos
    That said it looks ok but you can also buy them on ebay...
  8. Westy
    17,443
    1,104
  9. <tuffty/>
    21,354
    3,921
    Thats the fella... I know peeps that have ordered from them... at least I think it was them... that kits description suggests its the older kit...
    I seem to recall Bill ordering a kit from Latvia when he was first looking into the AEM stuff... maybe there are others...
  10. Westy
    17,443
    1,104
    My to do list has just gained another thing ;)
  11. Westy
    17,443
    1,104
    There's no filter with the above AEM kit but they recommend using a filter. Is this needed?
  12. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Dude I've heard about AEM kits off eBay from Latvia being fake/ not AEM parts.
    If Bill can't get the bits you need I might know a guy :)
    ps
  13. <tuffty/>
    21,354
    3,921
    Not fitted one yet... possibly worth a punt if you have the cash... did debate on it myself but I guess as long as you use clean jugs/bottles etc to fill the tank with and have too hard a water supply then should be ok...
  14. Westy
    17,443
    1,104
    I've already checked out your pics dude.
    Do you want to PM me some info about said "guy" you may know ;)
  15. Dane
    4,086
    182
    I'm finding out now mate :)
  16. badger5
    9,504
    2,003
    I doubt they're fakes..
    everything about them is AEM liveried and serialised
  17. Dane
    4,086
    182
    I could be talking out my **** though... lol
  18. badger5
    9,504
    2,003
    depends on nozzle size and controller.. and boost..
    12psi starting on low and 20psi full on is a guide.. logging will confirm whats best suited to your engine.. as will % of meth to water used
  19. tony696
    tony696 Member
    165
  20. Westy
    17,443
    1,104
    I have just managed to pick up the above Aquamist kit for a bargain £117. It has everything but a controller. From peoples experience is a controller really that important to gradually introduce water/meth or will a boost pressure switch do?
    I understand how the controller works and I will buy one if it is necessary.
  21. <tuffty/>
    21,354
    3,921
    Welly uses a pressure switch but its always nicer to make it more progressive...
  22. Westy
    17,443
    1,104
    Ah yes, and mr Welly flooded his TB with meth. I shall fire Welly a few questions when he's next on line.
    I may keep an eye out for a 2nd hand Devils own or AEM controller.
    Also I've read a lot of stuff about people only running water and wondered how much extra cooling/octane boost the methanol adds when injecting that mixed with the water?
  23. <tuffty/>
    21,354
    3,921
    Progressive is better overall tbh... its a bit all or nothing with a pressure switch which could well be a contributing factor to the failure of Welly's TB...
    Boost doesn't equate to airspeed or volume of air... 20v's don't really breath heavy until after 4k and if you are making 12psi (the boost I think Welly's kicks in) way before that then you have all the meth mix at a slower air speed...
    I have a Devils Own controller to fit once I have got the rest of my car sorted...
  24. Andy123
    Andy123 Member
    260
    The methanol has a high octane of about 116 from memory so you can advance the timing up more than just water alone. Water alone decreases the charge temps which supresses the knock, more timing again, but a combination of the two, 50/50 gets the best of both worlds. Water is free though unless you plan on using Evian or something like that?
  25. Westy
    17,443
    1,104
    Ahh ok. I was looking at the devils own boost pressure switch which allows you to set a pressure between 2-30psi for fine tuning.
    I'll keep my eye's peeled for a controller but in the mean time I might get the kit fitted up and just running water for a bit of extra cooling. I'll set it so it's only injecting after 16ish psi.
  26. tony696
    tony696 Member
    165
    i use a boost switch mate been on my car for about year now never had any problems
    but its up to you mate all depends how far you want to take it :)
    this is the one i got water methanol injection boost pressure switch | eBay
  27. Westy
    17,443
    1,104
    I read about a few instances where the mixture hadn't atomised enough before hitting the TB and caused issue with the TB. Welly's was one of them.
    I have however just spotted this which is fitted to Wak's TT
    This will inject the mixture after the TB but before the AIT sensor which is perfect. I might use just the pressure switch but inject after the TB to avoid any damage that might occur.
    Tony do you use water/methanol or just water? Have you had the cooling benefits mapped in on your car?
  28. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Have to be careful when you first install as I thought I was just using quite a bit of meth (wasn't to sure how much it should be using) then following day had a fair bit of water go through the engine just after start up to then find 2 litres plus in my cooler ;-(
    Bloody check valve wasn't working and over night had siphoned over 3/4's of a tank of meth
    On a plus side there has been no obvious side effects so think I was lucky and got away with that one :)
  29. Westy
    17,443
    1,104
    Are you running with a controller or just a boost pressure switch Stace? I'll have to take a look at your system when I come up to see you.
  30. StaceyS3
    2,505
    502
    Got the full aem kit with progressive controller and yeah no probs mate will hopefully have some new rims to show off by then as well ;-)
  31. Westy
    17,443
    1,104
    Anyone know where I can hold of a TB sandwich plate like the one shown in the picture above?
  32. Andy123
    Andy123 Member
    260
    What results has this guy got from placing it after the TB-does he say? You're not going to get the maximum benefit from placing it there mate especially so close to the AIT sensor and the water isn't going to absorb all of the heat you effectively want it to. Can't you place the injector right after your intercooler- this will give it enough time to atomize fully.
  33. Westy
    17,443
    1,104
    I was only looking at this as an option because a few people have has issues with the electric part of the TB failing due to the mixture corroding the PCB board.
    I'm struggling to find anywhere that even does these sandwich plates so it looks like I will be mounting it into the hose post FMIC.
  34. Westy
    17,443
    1,104
    How important is a check valve on these systems? I'm assuming the valve stops the mixture entering the bost hose when the car is switched off or not on boost?
  35. <tuffty/>
    21,354
    3,921
    I suspect the main reason for these failures is due to (in Wellys case) all the meth at once and in the case of Robbie with the LCR in links Welly posted poor atomisation....
    Decent atomisation is key to is doing the job its supposed to do... great big gobs of meth mix is gonna get in places its not supposed to... properly atomised it will be easily absorbed into the airstream and do what its designed to do...
    How not to fit a nozzle... (4th post...)
    Nozzle Location due to water/meht ingress/pooling - Devilsown Methanol Alcohol Water Injection
    Ideas on nozzle location pros and con etc...
    Where Do I Position My Water Injection Nozzles
  36. StaceyS3
    2,505
    502
    Very important I'm now thinking of putting a solenoid inline as well as like you say stops the fluid draining of it's own accord or being sucked in when on vacuum and should stop boost pushing it back to the tank 
  37. <tuffty/>
    21,354
    3,921
    Very... stop wmi syphoning into charge system when not running and boost leaking back to tank etc...
  38. <tuffty/>
    21,354
    3,921
    SNAP!! lol
  39. Westy
    17,443
    1,104
    Ok, check valve on order sheet too. My cheap kit is not looking so cheap now :faint:
  40. StaceyS3
    2,505
    502
    Great minds think alike lol ;-)
