Water/Meth Injection
AGU-TURBO Mar 30, 2011
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    anyone had any dealings with this on the 1.8t/s3.
    20-30 bhp increase
    advance timing
    run more boost
    lower intake temperature
    im also considering in a wotbox for santapod fun
    let me no you'r thoughts
  2. Turboman-a3
    Turboman-a3 speed thrills
    153
    I like the sound of it but how hard is it to fit?
  3. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Welly's hybrid thread is the best place for info
  4. AGU-TURBO
    616
    its very easy to fit apart from finding a suitable location for the Reservoir. im basicaly trying to find out if anyone has run this on a standard ko3.
  5. AGU-TURBO
    616
    ok cheers
  6. Dane
    4,086
    182
    Welly uses his windscreen washer bottle so it warns him when it's low
  7. <tuffty/>
    21,871
    4,199
    The AEM kits come with a pretty large bottle with a level sensor built in.. fitted an AEM kit to a TT over the weekend... the AEM controller is pretty good too...
    I have a Devils Own kit to fit to mine when I find the time... great for keeping IAT's nice and low for consistent performance... fit a lot of WMI kits to Ibizas running hybrid K03's and they work well...
  8. Turboman-a3
    153
    Mayb a bit of a group buy? lol
  9. J B
    J B Member
    140
    Is water meth injection suited more to a FMIC install, or would it be a suitable alternative to replacing the SMIC's with a FMIC? If that makes any sense :unsure:
  10. <tuffty/>
    21,871
    4,199
    Supplements rather than replaces... always advisable to replace the SMIC's with a FMIC regardless
  11. <tuffty/>
    21,871
    4,199
  12. AGU-TURBO
    616
    with the aem kit how big is the bottle. and were abouts did you fit it on the tt. also how long does it last and is meths preety easy to get hold of cheaply?
    thanks
  13. AGU-TURBO
    616
  14. AGU-TURBO
    616
  15. J B
    J B Member
    140
    Cheers tuffty thought that would be the case, armed with this information is it possible to ask for the dimensions of the 90degree alloy bends on your AH fabs IC. I will be getting one in the not to distant future & would probably make fiment a lot easier as I would like to maintain the 60mm pipework.
  16. Speedy Steve
    Speedy Steve Active Member
    1,258
    would you buy from Latvia? i will hopefully be buying one soon but not from them id rather buy from Bill !!!
  17. Turboman-a3
    153
    Devils own is cheaper but hasn't got the tank
  18. Turboman-a3
    153
    Yeh buying from badger sounds better
  19. badger5
    9,598
    2,060
    AEM is my preference of al the WMI kits I have used and sold/fitted previously
    I wont touch DO kits due to their poor reliability and tardy service support when they do go wrong.
    snow performance I used to use but their prices are too high imho for what you get
    aquamist i used originally but the pump was unreliable, extremely noisy, and very expensive to replace.
    AEM comes fully featured and of a higher spec than the others I have mentioned. Its a great kit
    Its not a complicated install, but it is very time consuming to do properly.
  20. Speedy Steve
    1,258
    i like the AEM tank with the water level sensor as Welly had the smart idea of using the washer bottle as it had the sensor this way you dont loose that huge screenwash bottle for the lovely clean roads we have over here that always seams to cover my screen. Although i dont know where to fit it. i was thinking in the passanger wheel arch with a quick connect hose by the battery but i cant remember how much space there is in there as idont want it in the boot
  21. AGU-TURBO
    616
    yes ive just had a good look at them AEM kits and they do seem to be the one's to go for. yeh welly's idea is good but i need my screen wash bottle. so yeh the aem kit ticks all the boxs for me
  22. AGU-TURBO
    616
    bit more info for anyone looking into buying one of these kits:
    • Increase horsepower safely by 10-15%.
    • Lower air temperatures by 50-200+ degrees.
    • Decrease cylinder temperatures up to 300 degrees.
    • Reduce the effects of heat soak in warmer climates.
    • Allows you to safely run more boost and timing.
    • Reduces carbon and helps maintain a clean combustion chamber.
    • Increases octane at user programmable boost levels.
    The main function of water methanol injection is preventing detonation. Detonation is caused by high temperatures and pressure developed in the combustion chamber. Water has a high latent heat content, which makes it extremely effective at preventing the onset of detonation. Water injection also reduces the production of NOx (oxides of nitrogen). Methanol, with its 116 octane and high flash point, further reduces the chances of detonation. While water is not combustible, it has a greater capacity to cool the intake air temps more than methanol alone. This is why we recommend a 50/50 mixture being misted into your boosted engine. Methanol also effectively increases the octane rating of the fuel, allowing performance gains when used in supercharged and turbocharged applications
  23. <tuffty/>
    21,871
    4,199
    I have removed my spare wheel as tbh the thing doesn't fit over my brakes anyway so looking to fabricate an alloy tank to sit in the spare wheel well where the pump will sit and storage for one of those VAG puncture kits with the goop and electric tyre pump...
  24. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Cooling Mist kit here from the States.
  25. AGU-TURBO
    616
  26. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Good shout about the spare wheel well, maybe a cheap redundant LPG doughnut on the bay?
  27. <tuffty/>
    21,871
    4,199
    Check it...
  28. Speedy Steve
    1,258
    Finally ordered mine today from Bill am looking forward to the fun job of fitting it.
  29. Lee172
    Lee172 GT3071
    430
    Im interested in wmi too but im still not sure where i can get the methanol from and how much it is?
  30. Speedy Steve
    1,258
    well im looking on ebay and 25l of 99.95 grade methanol is around 34.50 posted which at 50% mix will do 50l of mix and so 20 bottle refills
  31. Speedy Steve
    1,258
    or £100 for 205 litres hum might just have to go pick some up in my van
  32. Lee172
    Lee172 GT3071
    430
    Ok not as bad as i first thought, think bill told me 1 bottle will last around the same time as a tank of fuel? So what happens if you run out of methanol and carry on driving the car? I would probably go for 100 litres too but it wont go stale will it like petrol?
  33. Welly
    10,696
    130
    Nothing, just don't hammer it if you have had additional timing dialled in to suit the map....
  34. Speedy Steve
    1,258
    Paul just watch out as methanol can damage aluminium (well so i have read) Im guessing Virgin grade is ok to use
    Isnt virgin always better? lol
  35. Welly
    10,696
    130
    Virgin is the best way in my opinion......
    Anyway, moving on....
  36. S3 Sly
    S3 Sly Member
    122
    What triggers it, intake temps or boost pressure.
  37. Prawn
    11,663
    3,662
    boost pressure I think, prevention is better than cure!
  38. badger5
    9,598
    2,060
    on AEM kit, physical boost pressure and start point and full on pump settings are adjustable.
  39. <tuffty/>
    21,871
    4,199
    Yep boost pressure... progressive controllers used so they have a start boost and boost for full on... typically start at 12psi and on full at 18/20psi depending on setup of course...
  40. Speedy Steve
    1,258
    Right my WMI turned up today know have the real fun job of fitting it all. Bill/Paul i take it i dont need to wire in the blue and green wires. could i use the green wire onto an LED as an indicator that the tank is low? Dont shoot me ive only had a quick glance at the instructions
