Water leak!!!
matt blowen Jul 23, 2013
  1. matt blowen
    matt blowen Member
    181
    Hi guys and gals, please can somebody tell me what the white box underneath the scuttle is? Water is going underneath it and flooding my footwell. I have looked at pollen filter and its bone dry as is the surrounding area. Thanks matt
  2. <tuffty/>
    20,900
    3,710
    Drivers side? wiring loom coming out of it?
  3. matt blowen
    matt blowen Member
    181
    Yes thats the 1
  4. Greig300
    Greig300 Member
    253
    Ive just fixed my problem with my passenger footwell water leak. Problem was scuttle panel had dirt under it. Under the scuttle panel there is a clip the whole length that clicks to the windscreen mine was clogged with dirt which could not be seen outside in any way. Allowing water to drip onto the pollen filter and soaking inside. Made worse when the climate control was turned on it pissed out.
  5. matt blowen
    matt blowen Member
    181
    Glad you fixed it, i did notice the motor when i wipped out the filter to inspect but mine was dry.
  6. Greig300
    Greig300 Member
    253
    I'm pretty confident it's your scuttle panel that's causing your leak if you remove both wiper arms and lift the scuttle the whole bottom of your windscreen with have slimed dirt pushing the panel up off the clip. On my case the passenger side was most effected.
  7. matt blowen
    matt blowen Member
    181
    Ok thanks for the info i will have a good look when i get time.
  8. Greig300
    Greig300 Member
    253
    make sure you buy or get someone to use the correct removal tool for the wiper arms or it will crack your windscreen.
  9. matt blowen
    matt blowen Member
    181
    Ive already took them off. I opened the arm up then wiggled free off the thread.
