Water leak in boot
roston100 Dec 20, 2012
  1. roston100
    roston100 Member
    370
    Ive been having problems with my central locking for ages and when I looked at the convenience module in the boot i found it was full of water and was ruined - the water has also filled the space where my spare wheel sits.
    I have now changed the convenience module but the water issue is still there but i cannot see anything obvious that is causing it.
    Does anyone know of a common fault that could have caused this? Mine is a 3 door 2004 model
    thanks
  2. DeckedS3
    DeckedS3 Well-Known Member
    888
    306
    Seals around the rear lights sometimes leak. Have a look around there. Do you have a toe bar?
  3. roston100
    roston100 Member
    370
    nope, no bar!
    the lights have a little bit of moisture in them so ill take them out and look at the seals. thanks for the quick reply!
  4. mike foster
    3,967
    Leaking rear washer pipe. Leaks out through the wiper motor but also, if it has been blocked or frozen the pipe joint above the convenience module pops apart ! Stupid place to put a pipe joint !
    I had this on mine and to fix it I replaced the wiper motor and instead of popping the joint back together which never works properly, I joined the pipes with a length of smaller diameter pipe and used screw type pipe clips. It's been alright for two years now.
    Very common fault and it's surprising you haven't had boot lock problems as well.
  5. roston100
    roston100 Member
    370
    I read about the washer pipe but the amount of water is more than you would expect from a washer pipe - surely the water would just be from where i press the rear washer?
    The rear wiper works perfectly so i assumed it wasnt that?
  6. Ghost
    Ghost Booooooo! Gold Supporter
    2,389
    2,632
    What Mike said + 1
    .....and once fixed
    This time of year a drain my screen wash and replace with neat -9C will help prevent freezing and pipes splitting.
  7. Boon
    Boon Active Member
    441
    59
    My boot has recently had water ingress, turned out to be the seal around the fuel filler
