Water Leak From Front of Engine (2.0 Tdi)
Resin Rocket May 12, 2009
  1. Resin Rocket
    Resin Rocket New Member
    19
    Hi All,
    I noticed last night that theres a slight water leak that appears to be coming from somewhere behind the cambelt cover. I took the undertray off and could see where water has run down the alloy casting behind the bottom pulley.
    Is this a sign that the water pump is on its way out ? Car is a 2005 2.0 Tdi S-line thats done 45000mls.
  2. phille87
    phille87 Member
    86
    It depends, how much water is leaking?
    I had the same problem before but it was only the AC!!
  3. Resin Rocket
    19
    Certain its coolant thats leaking as the level has dropped and the water traces on the front of the engine match the colour of the coolant.
