water jet lines to rear in an avant
gtiboy Dec 24, 2012
  1. gtiboy
    gtiboy Member
    144
    can anybody on here tell me where to locate the water jet lines to the rear i and a6 avant c5 please .
    I have looked along the sills in side the car but to no avail.
    Thanks in advance
  2. mrnice
    mrnice Member
    156
    15
    It is taped into the wiring loom along the inside
    of the sill on passenger side under the carpet. It's
    a corrugated black plastic line. It has joins under the
    dash, under rear footwell, and in boot above the
    toolkit, all of which can pop off causing big leaks.
    If that's your prob I glued all the joins with epoxy
    resin and they're now fine. It can also split where
    the loom enters the tailgate and can pop off the
    back of the wiper motor inside tailgate. Mine has
    done all of the above!
    vorsprung bloody technical error...
  3. gtiboy
    gtiboy Member
    144
    I am sure mine is alright its wet at the tailgate so think mine as all the tailgate cover is soaking wet .
    took it off last night to have a look and was soaked as all the water was still dripping out .
    You would think audi as a company would sort out menial design faults eg wash system and plenum chamber problems before production ?
  4. mrnice
    mrnice Member
    156
    15
    Yep, some dodgy design there, only seems to cause probs
    At higher mileages by which time many of audis original customers
    have moved onto their next car so I guess they're
    not bothered by issues affecting folk trying to keep 10yr old mega mile cars with several prev owners on the road.
    The line tends to snap inside the rubber bung on the right
    Where it enters tailgate next to the hinge in case you want
    to check. Mine had had a previous repair with a piece of
    rubber hose, best if luck sorting it!
