Water ingress through tail light
bigcw Feb 5, 2014
  1. bigcw
    bigcw New Member
    Following on from my previous thread re: fuel pump issue (blown fuse due to water ingress) Read here
    So it seems the water coming in to the boot on my RS6 C6 Avant is coming from the offside tail light. I'm not 100% sure at the moment but it seems likely as the area behind the light is wet.
    We are talking about a huge volume of water. Knowing it was going to rain overnight I dried the boot thoroughly late afternoon yesterday. This morning I sucked approx 2 litres of water out of it with my shop vac. It did rain hard overnight, but there is no way that amount of water would have collected even if I had left the tailgate open.
    Has anyone experienced this before? Is there a known fix?
    Is there a gasket or seal of some kind that I can replace behind the tail light? I tried looking on the LED retrofit guides and can't find any mention of one.
    I know I could just take it out and silicone it up but that's a bit of a bodge!
    Chris
  2. Aly
    Aly Active Member
    254
    183
    43
    Do you have access to a smoke machine? Or can rent one? As I'd be inclined to pop one in to the car and see where the leak is happening to eliminate other possible issues....
  3. bigcw
    bigcw New Member
    I actually have a smoke machine, funnily enough, from many years ago when I was running a mobile disco... yeah, that long ago! Had not thought of that idea, worth a shot I guess. Thanks!
  4. Aly
    Aly Active Member
    254
    183
    43
    Let us know how you get on.. It does appear to be a lot of water! That's what's making me think it could be something else... Either way it will definitely help eliminate/narrow it down for you! Does your current light have a seal round it?
  5. RAF_S7
    RAF_S7 Well-Known Member Team V8 Gold Supporter Team Sepang Black Edition Audi S7
    683
    366
    Thats an awful lot of water for a leak originating from a light seal! - I know the UK has had some rain recently.....
    Ive see quite a few threads that mention leaking screen washer pipes for the back window. Is the water soapy or does it have that washer fluid smell?
  6. Music247
    Music247 New Member
    I had a similar problem spare tyre well was full of water. Try having a look at the seals around parking sensors on the inside of rear bumper. Had my parking sensor retro fitted at Audi and they went bad got them resealed now and no more leaks.
    Hope this helps someone.
    Audi A6 2007 2.0tdi
