Water in passenger foot well
Spatula Jan 20, 2014
  1. Spatula
    Spatula S3 8P
    257
    25
    Hi all,
    I've got a problem that I've had for awhile. My passenger foot wells (front and back) are always really wet.
    They're wet enough that when you press the carpet with your finger you can make a puddle appear.
    Does anyone have any idea where the water is coming from? I don't have a sunroof, and I don't think it's coming from door/window seals or anything. It's a 3 door 98 1.8T.
    Also, it's been happening for awhile now (maybe 3 months or so) and the car doesn't smell at all. ?
  2. Nilz
    11,300
    859
    If you do a search, it has been covered plenty of times.
    Common issues are scuttle panel not fitted properly, missing grommets, water lines blocked, so water comes into the car.
    Hope that helps.
  3. Spatula
    Spatula S3 8P
    257
    25
    Sorry, yeah I did a search after posting the thread, and found a whole bunch of useful information.
    I'll give them all a go when I have a little free time.
    Cheers anyway :)
  4. Nilz
    11,300
    859
    No worries mate, hope you get it sorted.
  5. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Yeh very common fault this, most likely the sunroof drainage holes are blocked, or the pipes have come loose !
  6. Spatula
    Spatula S3 8P
    257
    25
    I don't have a sun roof. Took door panel off and no signs of leak?
    I looked at the skutter* plate (plastic plate that goes under wiper blades) and theres a pretty big gap on passenger side between that and the window. Is this normal? I think I can see juice underneath but the gap looks too big for it to be sealed?
    Hmm... :confused:
  7. ruffrida
    1,926
    313
    Dont sound normal to me that, if i remember rightly mine was tight against the screen as the was a groove piece of palstic it sat/locked into. Dont hold me on that though!!
  8. Spatula
    Spatula S3 8P
    257
    25
    There is definitely a gap, probably around 2 or 3mm.
    Any ideas what I can do?
  9. ruffrida
    1,926
    313
    Defo not normal that fella!!
  10. Spatula
    Spatula S3 8P
    257
    25
    should that lip sit under or over the seal that runs vertical down the windscreen?
  11. Spatula
    Spatula S3 8P
    257
    25
    Do you think it'll be okay to use silicone sealant on the scuttle cover?
  12. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I was thinking the same... mine isnt bang flush but i was unsure about silicone to fill the gap.
  13. ruffrida
    1,926
    313
    The only way i would use silicone is if it could not be seen after, such ugly stuff makes everything look so tacky!!
    I would be having a look why the is a gap in the first place, fully remove it first make sure the is nothing causing the gap, dont forget they are really flexible so if it sits wrong on 1 end, i am pretty much certain it will be wrong somewhere else, you may not have even seen it.
    If i ever removed mine, i always made sure it was firmly up against the screen first before fully re-fitting!
  14. Spatula
    Spatula S3 8P
    257
    25
    I'm not even sure how I take the wipers off? Someone did a thread about removal and used a special tool to remove the wipers? Why can't they just be pulled off? Do I need to remove the bonnet or anything?
  15. ruffrida
    1,926
    313
    EH?? Special tool???????
    13mm socket and a screwdriver fella!
    Really simple, flip the cover up, undo the nut and pull !! That simple.
    Just make sure you dont damage the splines when removing and replacing. No need remove bonnet at all, just needs go up and down a few times so you can get the tools on right. Bout it fella.
    Once the are removed the scuttle panel should just pull of, can remember if the is a couple of screws holding in on or not, not that i can think of anyway, but remember they are only thin plastic so pull to hard and it will snap!!
  16. Spatula
    Spatula S3 8P
    257
    25
    Yeah I read a thread on here yesterday where someone had bought something from Halfords that looked like something out of Alien. I'll just pull that bad boy off.
    I'm getting excited at the concept of having a dry cabin..
  17. Nilz
    11,300
    859
    Good luck, let us know how you get on:)
  18. S3 Paul
    2,823
    107
    I took mine off at dinner time...
    The groove was full of dirt, i cleaned it all out but the trim still doesnt sit in... from about the middle of the screen about a foot towards the passenger side is raised. About 3 mill i would say. it pushed down but just slowly comes back up.
    I think some silicone sealer in the groove may be my next option... but i will need to clean it all properly first.
  19. Dani_B19
    9,048
    337
    Id say new scuttle panel paul. Easier and will look better.
  20. Spatula
    Spatula S3 8P
    257
    25
    I'm having huge problems getting my door panel back on. :-/
    I just looked at my scuttle thing and as s3 dave said; I'm seeing big gaps too
  21. Spatula
    Spatula S3 8P
    257
    25
    S3 paul* posting from app on phone
  22. ruffrida
    1,926
    313
    Yeh mine was minging, loads of **** in there, a real good clean of the scuttle panel and everything around it & it went back on nice and flush, all depends how many times some 1 has had it of & on, with most thin plastics it will only take so much !!
  23. ruffrida
    1,926
    313
    Or go with Dani_B19 idea save all the hassle / cleaning!!
  24. Spatula
    Spatula S3 8P
    257
    25
    Does anyone know the part number so I can call TPS and they can take my pants down?
  25. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    You need to clean the recess out very well, but perhaps the scuttle panel has been deformed because it's been in the wrong way for such a long time. A new one should work.
    I had to have a windscreen replaced once because it sagged on one side and dropped down so the scuttle panel would not fit in - every time it rained I got a wet foot well.
    Liam
  26. Dani_B19
    9,048
    337
    Its in a recent thread as I had a similar problem mate.
  27. S3 ROCKS
    S3 ROCKS steve
    216
    12
    Bit late on but hey ho. I had exactly the same issue after having my windscreen replaced. There is no doubt a small section of the scuttle panel fixing missing on the R/H side as you look at it. The result of this is that water is allowed to flow into the gap which conveniently sits above the pollen filter.
    This allows water to seep in and exit via the passenger footwell. More noticeably when washing the car you'll probably have a pool of water every time.
    Best option is to buy a new scuttle to guarantee a good fit to the windscreen and also that the recess where it fits to the windscreen is intact.
    Hope this helped
  28. Spatula
    Spatula S3 8P
    257
    25
    I've just had a quote for an OEM part from Audi.
    Part number: 8L2819415B 01C
    Price: £45.79
    I think I'll probably go for that.
    Dani_B19 likes this.
  29. Prawn
    11,370
    3,234
    I have this issue at the moment too, and it's BAD!
    My scuttle is cracked right above the pollen filter, and it's filled the heater up to the point where my heater motor has packed up, so I now can't warm up the inside to dry the car out!
    Fecking nightmare.
    New scuttle is being fitted as soon as I get a dry day to do it!
  30. Spatula
    Spatula S3 8P
    257
    25
    Oh dear, that sounds bad. Are you ordering a new one OEM, or getting on ebay or something?
