Water in footwell + rear washer jet not working + aircon knackered
munchkincoupe Jan 26, 2011
  1. munchkincoupe
    munchkincoupe Member
    948
    19
    Ok having fun with my car at the moment
    2004 2.0 tdi Sport 3 door
    Aircon hasn't worked since I got it - took it to a trusted aircon engineer and he's tried everything except replacing the whole aircon unit which is on my to do list but will cost me £480 all in
    Rear washer jet stopped working in the big freeze. Cleaned nozzle and it's passing water no problem. Stripped down the bootlid and no signs of water there. When i pull the stem to work it I can hear a running water sound around the drivers footwell somewhere
    Hoovered car out today and the carpet is wet under the front left side of the driver's footwell and it feels soapy and lathers slightly when I rub it
    Does the rear washer tubing run through there or do you think it's related to the aircon?
    Would the front bumper need to come off to replace the aircon condenser? ie, could they fix the washer jet at same time as aircon?
    Am I barking up the wrong tree?
    Thanks for your help
    I have done lots of searches but nobody seems to have all 3 problems at once :tapedshut:
  2. mike foster
    3,967
    I believe the rear washer tubing runs through that area but it also sounds like the aircon unit needs a good dose of looking at !! Fix rear washer first and then look at the aircon.
    What is the third problem ??
  3. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,227
    319
    yes the pipe runs there it has a joint i think in the drivers footwell area so it has prob come off thats why its soapy its your screen wash all over your carpets lol
  4. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    The pipes either popped off or split in the cold weather if the car gor frosted. Happened to our A6 in 3 joints!!! Loads of water lol!
  5. FranA3
    7,227
    319
    mine has messed up too but the snow has snaped the spring in the wiper arm so its either de wiper time or aero wiper time still cant decide lol , any luck with your car sarah ??
  6. mike foster
    3,967
    Like I said in an earlier thread - don't blame the snow - never try to clear snow off a screen with the wipers !!!!
  7. Sarah's A3
    5,920
    30
    Hiya Fran, its back in Friday....again!! lol
    Looks like its the inner CV joints! Could be both too, just hope the outer ones are ok. Will let you know after Friday how it goes.
  8. Sarah's A3
    5,920
    30
    Fully agree, never use the wipers!
  9. FranA3
    7,227
    319
    i didnt use it , it snapped as i put up the wiper to clear the snow off the car must have been too cold and brittle or something , i allways clear the snow off by hand i know what i does to your wipers and the motor too
  10. FranA3
    7,227
    319
    hope it gets sorted out finaly eh
  11. Sarah's A3
    5,920
    30
    Aero wiper is far better tbh, just my thoughts. Will look great on your car too.
  12. Sarah's A3
    5,920
    30
    Yeah its driving me mad and im getting paranoid other stuff will get damaged the longer it takes to sort! Seems theres play in the drive shaft with up and down movement. But cant wait til hes sorted, love my car and its spoiling it.
  13. FranA3
    7,227
    319
    me too every noise i hear i think whats braking now lol im going to take my car to the garage that did my gearbox next week as the noise its making is the same noise it was making before it went bang and i dont want that happening again it cost me £650 to fix that money is my facelift money or new wheels lol
  14. Sarah's A3
    5,920
    30
    Best get it back there, gives peace of mind.
    Yup you need to save the pennies as this summer could be your conversion!
    Odd isnt it, the myth Audis are reliable lol!
  15. FranA3
    7,227
    319
    yeah it is peace of mind im hoping its just an engine mounting gone thats alot cheaper than another gearbox lol , yep i wasnt going to do it i had second thoughts but now ashley changed my mind again im just going to do the sport full frame grill for now with a black fk grill and a votex front spoiler and maybe add the s-line front bumper later on when moneys a bit better , sport bumpers on ebay are cheap as **** loloh ps.. soz for the thread hijack lol
  16. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    Given that a lot of the components that might give trouble like coil packs and ignition systems Suspension, uj's, CVJ's etc are bought in, off the shelf parts as fitted to most other cars its not surprising the reliability is average. One of the biggest failures of the Bentley coupe is the coil packs and guess what ? they are straight swap with Audi :)
  17. FranA3
    7,227
    319
    my audi has never failed to start which is a good thing but two of the coil packs have gone in three years but at £25 from euro car parts they arent that baddly priced
  18. munchkincoupe
    948
    19
    Anybody got any idea of how to get to it to see if I can sort it myself?
  19. NHN
    29,298
    1,701
    Remove seat, side plastic trims, lift carpet & hold it up with some wood to get a torch in & check mate, probably expanded water pipe in cold weather & its cracked, I dont think its too bad a fix, could cut & join, whack some sikaflex or some sealant round the joint, leave for a day then test, if ok, test with constant pressure to make sure seals are holding then refit everything.
  20. munchkincoupe
    948
    19
    NHN - thanks for that - does the pipe run along the central tunnel then or along the edge of the car and is running into the lowest part of the footwell?
  21. paddy
    5,152
    133
    You can buy push in connectors in Halfords ( odd packs) if you need to cut out a split and make a join.
    Well worth running at least 50% screen wash during the winter to avoid the pipe freezing.
    Pretty sure the pipe runs on the side, not the centre.
  22. NHN
    29,298
    1,701
    Yeah I'm also sure it runs down the same channel as the looms, so right against the edge.
  23. munchkincoupe
    948
    19
    Thanks fellas - I've swapped several car interiors before so should be ok just never had to lift a carpet before!
  24. munchkincoupe
    948
    19
    Anybody know what mm the washer tubing is please?
  25. mike foster
    3,967
    6.0 x .75mm in 10metre lengths
    Part no. :- 1J0 955 751 D £16 ish
    You can buy couplers as well
  26. NHN
    29,298
    1,701
    I see Mike's straight tonite :p
  27. munchkincoupe
    948
    19
  28. FranA3
    7,227
    319
    lol
  29. mike foster
    3,967
    Yeah - not been out tonight - bet I can't sleep now !! :(
    Steady with the 'straight' bit - people may get the wrong idea !!!!! lol :ohmy:
  30. NHN
    29,298
    1,701
    Yeah you may get our resident GAYLORD approach you lmfao
  31. mike foster
    3,967
    What !!!!!!! :eyebrows: That's it - I'm off :lmfao:
  32. Sarah's A3
    5,920
    30
    Think hes around somewhere!!!
  33. mike foster
    3,967
    He's not the one with the poofy looking red car is he ???? lol ( that narrows it down a bit!! ) :scared2:
  34. munchkincoupe
    948
    19
    Washer tubing had separated at the joint to the right of accelerator pedal. Dried carpet and underneath as much as possible. Resealed the joint with high pressure hose instead and cable ties + sealant. Pressure tested and all good. Refitted trim and seat. Now got airbag light on but that will get cleared next week when exhaust tips go on - just the aircon to sort now!
