water from exhaust,white smoke
vw754 Mar 16, 2012
  1. vw754
    vw754 vorsprung Durch Technik
    2,331
    58
    2.0 tdi cab (my cousins car) 58,000 miles dealer history......white some and water can be seen from the exhaust,but only sometimes,the car does not lose any water......and theres quite a bit of back pressure when you pull out the dipstick or oil filler cap off........could this be the dpf? cant see the headgasket being an issue ...its a weird one this......anyone?
  2. *Adam
    *Adam Member
    55
    It only takes a small amount of water to produce the white smoke as I have just found out. I'd get a compression test done on the coolant system and work from there.
  3. Mike B
    Mike B Well-Known Member
    1,101
    40
    I would be concerned about noticeable back pressure fromthe cap cos I have heard that this shows that the crankcase breather is blocked and this might be the white exhaust,A coolant pressure test is a good idea to check that the system is sound
  4. vw754
    2,331
    58
    thiss is at the top on the 2.0 tdi?.........top of the rocker/cam cover?
  5. Mike B
    1,101
    40
    Sorry I dont know the 2.0tdi mines a B6 2.5tdi and I have that earlier versions suffer the blockages and a symptom is this pressure build up
