Water Dripping
Dom Knight Sep 24, 2013
  1. Dom Knight
    Dom Knight Member
    53
    For some days I have noticed a wet patch on the drive.
    Looking underneath the car just to the rear of the engine is a drip.
    So I collected the water and sure enough it was water and clear.
    I even tasted it and it has no chemicals in it.
    I lifted bonnet and that chassis beam at the bottom and to the back of the engine has quite a bit of it sitting on it as the beam as it is concave.
    Not having washed the car for a while, I cant figure where it's coming from.
    The washer bottle is topped up and the level is unchanged.
    The engine coolant is at the same level too.
    Is it possible the water is leaking from the air con system ?
  2. Clart
    Clart Audi S3 Section Mod Gold Supporter Audi S3
    928
    235
    43
    Could be condensate from the air con? I noticed the same thing last weekend on my S3... Only had it two weeks, so I'm looking forward to the replies from this post...
  3. LynxE
    LynxE Member
    104
    14
    I'm interested in this too. I noticed the same thing from the same place from mine a couple of weeks back then last weekend a slight hiss after I switched the engine off that sounds like it's coming from under the gear stick. It's only a very slight drip and all my bottles are topped up. Like Dom said, is it the aircon?
  4. LynxE
    LynxE Member
    104
    14
    lol, same time Artsa. Only had my S3 since July so fairly new to them too.
  5. Clart
    928
    235
    43
    I love my S3... Awesome car :) Brings a smile to my face every time...
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Turn off the aircon and see if it stops...;)
  7. Fast Road
    Fast Road New Member
    19
    Yeah that
  8. Dom Knight
    Dom Knight Member
    53
    Not had the air con on for a week at least and the temp is set to 69
  9. egesford
    egesford Member
    346
    it can only really be the aircon, all my car do it except for the one that doesnt have aircon
  10. JudderMan
    JudderMan Well-Known Member
    1,010
    167
    Air con, definitely. It's the condensor condensing. Hot engine near a cold refridgerent thing makes it condense and drip.
    btw, kudos for tasting it! That's commitment. Usually a sniff will do. If it was antifreeze you would probably be violently sick LOL.
  11. Dom Knight
    Dom Knight Member
    53
    I am certain now it's the air con unit.
    Doubt we will get the system on now as winter is on it's way.
    So hopefully the drip will stop in good time.
    And there was a time when you could drink antifreeze because of it's alcohol content.
    Alas they put a stop to that some time back by adding something that made you sick.
  12. JA50N
    JA50N Member
    85
    I am just searching and maybe need help soon as i have a water leak but the drips from where you say is air con (condensation drips) as mine has it there but is also leaking coolant from rear believe top of engine as it is running down and that has a taste of antifreeze
