Wastegate/Screamerpipe?
Bigphil92 Apr 26, 2010
  1. Bigphil92
    Bigphil92 Member
    61
    hey guys i have a 1.8t 51 plate a3 and i was just wondering what wastegate or screamer pipe would fit my car? size?
    thanks phil
  2. Y83OLK
    Y83OLK Hulk Smash!
    841
    If your running the standard turbo, its internally gated.. Thus cannot run an external wastegate or screamer pipe.
    sorry chap.
    size?.. 52mm
  3. future
    future Scuderia Vittoria Edition 001
    372
    33
    the man speaks the truth and screamer pipes are illegal if you want a road going car iirc
  4. 1animal1
    9,978
    what the hell is a screamer and why would you want one fitted (been meaning to ask)
  5. ALPINE
    3,093
  6. Bigphil92
    Bigphil92 Member
    61
    ah fair enough is the ko4 the same aswell?
  7. <tuffty/>
    21,697
    4,126
    yes and just as illegal.... :icon_thumright:
  8. Bigphil92
    Bigphil92 Member
    61
    haha ah well dont worry about that bit :p
    are there any turbos you could get for the car without having to get forged internals?
  9. <tuffty/>
    21,697
    4,126
    A K03s LOL.....
    You can go K03 hybrid (K03 with K04 internals) but still would be advising a rod change as they are spiky as hell.... Pistons and crank are already forged on the 1.8t's...
    You will of course need to change the injectors, MAF housing, TIP, air filter and most likely use and LCR (if FWD) or S3 (if quattro) fuel pump... a bit of custom mapping later and you will have S3 power (260bhp, 280ftlbs)... more can be had with 3" DP, FMIC ect too
  10. Bigphil92
    Bigphil92 Member
    61
    ah right well if i save up 4 grand then ill be sorted for everything :p
    mine is the aum code doesnt it have a ko3s?
  11. <tuffty/>
    21,697
    4,126
    Yarp... :)
  12. 1animal1
    9,978
    ok so the advertt says it adds power..... does it actually add power or are we talking K&N style marketting..... other than that im struggling to see the benefit
  13. Bigphil92
    Bigphil92 Member
    61
    where could i get some s3/tt injectors?
    also would they make any difference before the ko4 goes on with the ko3s?
  14. 1animal1
    9,978
    off an S3 or a TT :)
  15. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Dammit, too slow Tim!
  16. Bigphil92
    Bigphil92 Member
    61
    haha well nah :p
    but is there a shop that sells them or shall i just go to a breakers yard or something
  17. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    Isn't the K03/K04 compressor shaft to weedy to handle stalling anyway?
    Also, I didn't realise screamer pipes were illegal. Every day's a school day!
  18. <tuffty/>
    21,697
    4,126
    Leon Cupra R use the same injectors too... 370cc IIRC...
    Don't fit them before doing any upgrade else you will just flood the engine... The map needs to be told what size injectors it has and will think it needs to use the same duty cycle as for the smaller ones... you will get more fuel delivered for the same injector on cycle but have no extra air to support it making the mixture too rich...
    The K03 hybrid is a very popular upgrade path for Ibiza and Leon Cupra owners on SCN (SEAT Cupra Net)...
  19. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    why is it illegal?
  20. JD09
    3,096
    46
    Because they dump exhaust fumes out the bottom of the engine, rather than sending them through the cat/exhaust. They are very loud and pretty damn bad for emmissions!
  21. Y83OLK
    Y83OLK Hulk Smash!
    841
    How would a screamer pipe fair against an MOT cat test?.
  22. 1animal1
    9,978
    well its not sending the fumes threw the CAT which i why its illegal..... its not sending it through anything
  23. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I had a mate who took a girl up the screamer pipe once :lmfao:
  24. Bigphil92
    Bigphil92 Member
    61
    also what power is possible with a stage 2 remap on an aum engine 1.8t?
  25. ALPINE
    3,093
    did she squeel like a piggy? :undwech:
  26. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    LOL
    I wonder where the fumes would come out then?
  27. james0808
    james0808 Active Member
    3,548
    Ferrari used a screamer pipe on the F40.
  28. Bigphil92
    Bigphil92 Member
    61
    for a stage 2 remap do i have to put the exhaust and intake stuff on then remap it again or does it just make it a stage 2 by putting that stuff on?
  29. 1animal1
    9,978
    they more than likely wont stage 2 it till you put those on....stage 2 is only a movement from stage 1 where the map is tweeked to take advantage of the mods......for example you could change ll the parts you want but if the exhausts ristricts anymore power...then ya buggered......
  30. badger5
    9,561
    2,030
    and F40 would'nt pass todays regs..
    I dont think screemer pipe is illegal, and would'nt effect an mot emissions test, as its not venting on the idle and fast idle tests.
    I would imagine the cops would pull you when its on an open road and actively screaming tho.. as its loud.. and pretty unsociable
  31. Matt82
    Matt82 Active Member
    2,365
    i agree with bill. the main issue youd have is noise, but from what ive heard theyre no worse than your typical straight through no silencers exhaust
