Wastegate flutter?
s3 Hoggy Feb 15, 2010
  1. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Hi all,
    I have just had a forge TIP fitted and I seem to have developed a flutter on lift off? am I right in thinking this is very bad? I have a forge 007p recirc valve and it usualy gives me a light woosh sound but now thats completely gone!
    Any help would be fantastic as I'm quite worried at the moment as not sure if this is damaging my turbo?:sadlike:
    Cheers Matt
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    I'm not sure if it works in the same way with recirc's as atmospheric (in fact I think it doesn't!) but wastegate flutter basically means that the air is passing back through the turbo and effectively stalls the turbo. So yeah it isn't good!
    Does it happen if you lift off quickly? I'm fairly sure that the main cause of flutter is when the throttle plate snaps back quickly, or if the throttle plate isn't opening quick enough you can get a bit as well.
    It's all down to the throttle plate really, try gently working it up to boost by slowly accelerating in 2nd or third up to about 2 and a half/3K and see if you can hear a bit of chatter on the way up to full boost pressure. Let us know what its doing under those sorts of conditions and we might be able to help :)
  3. s3 Hoggy
    1,716
    158
    hello mate thanks for the reply there is no flutter on the way up or on boost only when lifting off? Could it be down to the recirc valve?
  4. s3 Hoggy
    1,716
    158
    I'd Just like to add im not driving hard as I have just had a new clutch fitted today also
    Cheers Matt
  5. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,231
    2,052
    I get it and also I know minty has it as well and we are still good
  6. s3 Hoggy
    1,716
    158
    Thanks Jase I was hoping for a reassuring comment! the work was all done at APS I phoned them and they seem to think its fine also
    Cheers Matt
  7. golf
    golf ***** rent boy VCDS Map User
    1,556
    A fluttering sound should never be heard from any of the DV's on a 1.8T.
  8. s3gav
    s3gav Member
    413
    mine does it to has done since i fitted my forge dv over a year ago never had a problem
  9. s3 Hoggy
    1,716
    158
    I think I'm going to take my recirc valve off at the weekend and re-fit the original one? might be worth a try to see if theres a problem there, It just seems wierd as its only started today after fitting tip and now lost the boost dump sound?
    Cheers Matt
  10. Andrew@A.L.D
    3,879
    617
  11. s3 Hoggy
    1,716
    158
    I was thinking that but its just the standard spring? would it make this flutter if its not dumping properly?
  12. R-Tech-Nick
    R-Tech-Nick Active Member
    150
    51
    It should not flutter with the green or yellow springs, I would check all the small vac lines, Check the line going to the top of the DV and see if its pulling a vac on idle.
    Nick
  13. Andrew@A.L.D
    3,879
    617
    The valve could be sticking? No or little vacuum to operate the valve?
    Is there any fault codes coming up?
    If the N112 valve is faulty then its may not open the valve?
  14. s3 Hoggy
    1,716
    158
    If I were to check this would I just take the pipe off and start the engine an see if its sucking? sorry im not very technical!
    Cheers Matt
  15. s3 Hoggy
    1,716
    158
    Woohoo I've just found a split in the small pipe going into the top of my 007p! Would this be causing my problem? It seems it would!
    Matt
  16. Matt82
    Matt82 Active Member
    2,365
    wastegates do not flutter
  17. <tuffty/>
    21,685
    4,111
    I would think so... if that pipe is split then the DV won't be working 100% thus not dumping the excess pressure and bringing on the onset of compressor stall which sounds like the noise you are hearing..
  18. Andrew@A.L.D
    3,879
    617
    Arr no vacuum to open the valve, there you go
    Is it better?
    I had that problem with mine were the previous tightened the clip to tight and split the hose
  19. ianysm
    ianysm Active Member
    1,002
    Got a pic of this pipe?
  20. s3 Hoggy
    1,716
    158
    I'll get it sorted in the morning and I'll report back, thanks to everyone who's helped out!
    Cheers Matt
  21. s3 Hoggy
    1,716
    158
    I'll take a pic in morning mate
  22. golf
    1,556
    If it was, indeed, compressor stall then just have a quick look to see that the turbine hasn't been damaged as the shaft of the KO4's are thin and can't take much abuse.
  23. s3 Hoggy
    1,716
    158
    How would I have a quick look? Is there an easy way mate?
  24. badger5
    9,553
    2,027
    the k04 will be fine.. sustained high boost no DV then yea I would be more worried, but not like you describe.. You wont observe a thing just looking and touching it
  25. s3 Hoggy
    1,716
    158
    Cheers Bill
  26. s3 Hoggy
    1,716
    158
    Fixed!!!!!!!!!
    Cheers Matt
  27. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    My n249 valve broke which caused the fluttering on mine, plumber the dv direct to the inlet manifold and its fine although the dump noise does sound different, almost like a slight stall but not sure...
  28. ALPINE
    3,093
    whilst were on the subject of VAC etc, My boost gauge only reads -4 to -5 psi of vac. on other turboed cars i have had its more around the -20 mark. i dont have any flutter but when i change gear the needle on my boost gauge flutters down instead of just dropping to -20. Why??
  29. badger5
    9,553
    2,027
    idle vac having a small leak would reduce your manifold vacuum on idle.
    if you have vagcom have a look at block 032 and see what % lambda adjust is doing on short term (first block)... a higher +ve number is compensating for additional air getting in... aka leaky pipe
    (up to 3-5% is probably ok)
