  1. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
    Hi,i've noticed on newer models of A3,the spray pattern for the wipers now uses 3 jets each side,giving much better coverage. Is it possible to retrofit these? Can i do it easily? I have an S3 8P,07 chassis.
    If so,how much are they?
    regards,Gary
  2. stoke_audi
    stoke_audi Active Member
    2,243
    19
    Hi Gary
    the non heated ones are £4.55 each
    heated £13.30 each
    P&P extra
    not sure if they will fit straight in but look the same, just pull old ones out i guess and replace with new ines
  3. Fast,not furious
    416
    I thought they were heated,as standard on an S3? I'll take some,just looked at mine,they've a small unit wired to them,i guess that's the heater? There's a number on the back - 8PO 955 988. Whats the total cost please?
  4. Nelson_R32
    Nelson_R32 Member
    305
    The will not fit straight into the older type scuttle panel. I believe there is a retrofit kit on section 0-97 of ETKA though now though.
  5. stoke_audi
    2,243
    19
    Nelson could you please not advertise in this forum ,
    as this is a funded parts forum by ourselves
    Thanks Dave
    Parts Manager
  6. Nelson_R32
    Nelson_R32 Member
    305
    Apologies Dave; I forgot to remove my signature from the previous post. I'll see if I can edit it.
    FYI; I tried this mod on my 2007 A3 a while back and the only obstacle is the scuttle panel. You could either be clever and cut the scuttle panel (I didn't fancy this in case I cocked it up) or fit a new scuttle panel.
    The '3 jet' washer retrofit kits it appears on ETKA as only applicable to A4 B6/B7 and C6 A6. Part number 4F0898101. BUT because it's a retrofit kit its more cost effective to buy the kit and throw away the bits you don't need as buying the two jets seperate is more expensive.
  7. stoke_audi
    2,243
    19
    Thanks for that
    Dave
  8. StagsyA4
    StagsyA4 Member
    96
    Sorry to sound dumb but can someone please tell me what ETKA is?
    Cheers.
  9. stoke_audi
    2,243
    19
    is the programme we use to look parts up and identify them from chassis number
