Washer Jet Questions
giblets46 Dec 3, 2010
  1. giblets46
    giblets46 Member
    156
    Hi, with the cold weather, and gunk all over the roads I have a couple of washer jet related questions!
    • Heated Washer Jets: I've read two things about these, one says they come automatically below a certain temperature, the other says they come on with the rear windscreen heater (and another states the wing miror heaters should be selected). Which is it?
    • Headlight washers: Do these spray everytime you spray the windscreen? One in ten times? Only when headlights are on?
    Cheers!
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    One in 10 times with the headlights on.
  3. redspudder
    redspudder Sparky
    371
    Or if you hold the windscreen washer stork back for i think its 5 seconds
  4. scoTTy
    scoTTy Active Member
    1,962
    Not any more. The B6/7 solution was much better i.e. you controlled it.
    Now it's automated. I played with VCDS trying to change it to how it was but I've have had to set it to a higher number between washes.... infact since I've just had my 3G software upgraded and all my settings have gone, this is one I need to re-do.
  5. Shadowman
    Shadowman Active Member
    592
    43
    My B8 is the same as Redspudder's.....hold the stalk in for more than a few seconds and the headlights wash as well.....every time.
  6. giblets46
    giblets46 Member
    156
    Thanks, just the heater system to work out now!
  7. scoTTy
    1,962
    Yeah sorry.You're right. I was confusingmyself ... and then everyone else!
    "The headlight washer system only operates when the lights are switched on. The headlights are automatically washed the first time and every fifth time you move the lever to position 5. The headlights will also be washed if you hold the lever in position -5- for longer than 2 seconds."
    Position 5 is winscreen wash.
    I was trying to disable the 5th time thing.
  8. chappelle
    chappelle New Member
    Does the B8 have as standard heated washer jets, or is this an option?
    Ran a B6 S4 for a long time and never had a problem with washers freezing. Bought an ex-Audi B8 S4 and the washers keep freezing up.
    Had a quick look and pretty sure there are no electrical connections. Any ideas?
  9. scoTTy
    1,962
    I believe all have heated jets in fact I can't believe they wouldn't have. Perhaps it's not the jet that's frozen but the bottle. Since it's new to you maybe someone didn't maintain the correct mix?
  10. Zafi
    Zafi Well-Known Member
    1,282
    320
    A week or so ago we had a thaw, so I sat in the car with the washers running constantly until the bottle was empty, then refilled with neat quality washer fluid.
  11. scoTTy
    1,962
    I'm getting deja vue!
  12. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    heated washers my ****.Doesnt matter what mix of screenwash i have, ive never been able to use my washers when its cold.
  13. scoTTy
    1,962
    Weird. I've never had an issue on my TT, S4 or A4.
    I use Audi's fluid and vary the mix according to the season. Perhaps that's it ... or maybe it's coz I live in the tropical south ;)
  14. rosscotdi
    rosscotdi Member
    118
    Halfords -15 (neat) stuff works a treat, and currently its -8
  15. scoTTy
    1,962
    Audi goes to -70 and my mix means I'm currently good to -30.
    Overkill? Maybe but I don't have it freeze on the screen when I apply it or suffer blocked jets etc.
  16. Big Bird
    Big Bird Member
    116
    15
    How much is the Audi stuff???
  17. scoTTy
    1,962
    I've not bought any for ages as last time I bought a number of them and of course you dilute them but the website says £4.25
    Audi Accessories < Owners area < Audi UK
    I guess if could get expensive if you're doing big miles or the conditions get really mucky so that you use gallons of it.
  18. rosscotdi
    rosscotdi Member
    118
    Nice one scotty, off to the dealers tommorrow for me
  19. ScottD3
    15,162
    1,123
    is the VW stuff the same?
    The closest Audi dealer to me is the other side of town and VW is 5mins.
    Most of stuff comes from them. lol
  20. scoTTy
    1,962
    Yep Audi, VW and Skoda is all the same. I even checked the price at Skoda in case I could save a few pennies but I couldn't.
  21. giblets46
    giblets46 Member
    156
    I got some pre-mixed Sainsbury's stuff the other day after the last lot ran out, about as much use as a chocolate tea pot.
    Had it in a week, and washer barely work ever, just read the label, for winter weather down to -2c!!!
  22. ScottD3
    15,162
    1,123
    Off to VW when i can get out of my road.
  23. Necroscope
    Necroscope Member
    254
    Audi chrome is also known to stain when using cheap screen wash, so watch that too....
  24. chappelle
    Thanks Scotty. Poured in neat concentrated washer fluid bought in Costco when the bottle wasn't empty and it seems better.
    Otherwise car goes well in the snow. Was a bit worried about going from a manual to the S-tronic but so far it seems to go without problems
