washer fault
1wheelonly Jul 7, 2011
  1. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    hi all, not been on for a while, maybe someone could help me out here.
    my brother in law has bought an 06 plate vw eos, it has a fault that there is no washers on front windscreen.
    heres the scan
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Control Module Part Number: 3C0 937 049 Q HW: 3C0 937 049 Q
    Component and/or Version: Bordnetz-SG H46 1501
    Software Coding: E5069E0700041500470A00000F00000000095D035C0000
    Work Shop Code: WSC 00020 000 00000
    Additional Info: 1K2955119E Wischer 120606 020 0501 1K0955559AE RLS 250506 014 1201
    VCID: 37794E753FCB
    2 Faults Found:
    00156 - Control Circuit for Windshield Washer Pump
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 57483 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    02390 - Control / Regulation for Ambience Lighting (E400)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 57483 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    in measuring blocks its showing that the stalk is talking and showing readings as it should, at the central electrics module, i can supply 12v directly to the plug and washer bottle kicks in.
    all fuses and relays etc are fine.
    with the headlights on the headlight washers work fine from the same stalk.
