Warrantys
jjarvis Jan 12, 2006
  1. jjarvis
    jjarvis Member
    70
    This any good? £300 for the year through warranty direct.
    Covers the following:
    Close Window
    DriveLine
    for general details of cover see Policy Documents
    The items under the following list are covered. Any item not specifically mentioned is not covered.
    ENGINE
    Cylinder head
    Cylinder head gasket
    Valves (excluding decarbonisation, burnt or pitted valves and valve seats)
    Valve springs
    Valve guides
    Camshaft and bearings
    Cam followers
    Hydraulic lifters
    Push rods and rocker gear
    Timing gears
    Chains
    Belts and tensioners
    Pistons
    Piston rings
    Cylinder liners and linear seals
    Connecting rods and bearings
    Gudgeon pins
    Crankshaft and bearings
    Oil pump and oil pump drive
    Distributor drive gear
    Distributor drive
    Flywheel and ring gear
    Flex plate/auto drive plate
    Inlet and exhaust manifolds.
    TURBOCHARGER
    Internal failure of factory fitted turbocharger and wastegate.
    GEAR BOX: MANUAL AND AUTOMATIC
    Gears
    Shafts
    Synchromesh hubs rings and selector shafts and forks
    Extension shaft
    Torque convertor
    Automatic transmission clutches and brake bands
    Oil pump
    Bearings and bushes
    Valves and valve block
    Governor and servo.
    TRANSMISSION
    Crown wheel and pinion
    Differential gears and bearings
    Bushes
    Half shaft and half shaft bearings
    Driveshafts
    Bearings and constant velocity joints
    Propshaft universal joints and centre bearing hubs and wheel bearings.
    Only the components originally fitted as standard by the manufacturer are covered.
    CLAIMS: 0870 750 0125
    Fax: 0870 750 0126
    Administration: 0870 750 0127
    Email: info@warrantydirect.co.uk
    Website: www.warrantydirect.co.uk
    Close Window
  2. Mart
    Mart Active Member
    1,224
    I just paid £345 for a Two Year warranty!
    Throught Car Protect! It's a Dealer Care Extended Guarantee!
    Includes Turbo, Aircon Windows, Engine, pretty much everything you've just quoted
    Generally Manufactured original parts
  3. jjarvis
    jjarvis Member
    70
    Ooh, thats not a bad price at all. Do you have to pay up front or can you do it monthly?
  4. Mart
    Mart Active Member
    1,224
    I paid upfront, through the dealer (when I say dealer, I mean trader) who sold it to me.
    Did ring the company up, and was offered monthly payment!
    Their contact no is: 08707 559666
    Not sure if they even do warranty for someone who hasn't purchaed a car through a selected dealer who offers! But ring them and find out if you like.
    Hopefully you'll get a good price also!
