Warped discs after 5k miles
Brodster Nov 17, 2012
  1. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    As the title says the front brake discs on my S3 are now warped.....WTF. They must be made of cheese. So the cars into the garage next week to get all the wee niggly problems sorted. The worst one is trying to fill the car up full of fuel. Almost impossible unless you have about 15 mins spare. When you think its full, drive away the needle moves away from full after about 5-10 miles. I have tried to fill it right up and it takes about another £10-£12 so sounds like there could be a restriction at the top of the tank.
  2. mjr901
    mjr901 Guest
    Mine moves after 12 miles! Its a slow and painful process brimming it.
  3. Sidhu88
    Sidhu88 Active Member
    808
    76
    Were ur discs and pads changed together last time round? Did u wear them in properly? Who installed the old ones?
  4. Brodster
    3,553
    896
    The S3 is only 6 months old with 5k miles. Noticed it yesterday when coming back down the road from picking the kids up at Lossiemouth. Bad vibration through the pedal and steering wheel. Take your foot off the brake and everything is bob-on.
    Its going in next week as I said to get it sorted and Im just waiting for them to say theres nothing wrong......bring it on!!!
  5. mjr901
    mjr901 Guest
    Suprised they're not rusty :jump:
    I got mine in Feb brand new, I'm now on 14,200 miles :)
    Drive a bit harder? ;)
    Time to upgrade to HUGE brakes?
    Audi will probably replace under good will?
  6. Shadowman
    Shadowman Active Member
    592
    43
    Had my discs & pads changed after 8k miles...same issue exactly....no quibbles from them about replacing everything either which leads me to think it is a known issue on some cars.
  7. mjr901
    mjr901 Guest
    You've been quiet y'old chap!
    touch wood, my brakes work very well :)
  8. Brodster
    3,553
    896
    They brakes are still very strong but I can't handle the wobble coming thro the wheel and pedal. I have heard that it is a fairly common problem. And IF Audi don't change them under warranty then my alter ego will be coming out.......:shutup2:
    Quick question though......seeing as my car has non OEM alloys on it - 19" BBS CK's will this make any difference to the warranty stuff????
  9. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,250
    2,073
    Bloody hell thats bad,my bro had a Peugeot which needed new discs and pads after 3 months.....but an Audi ! Sacre Bleu :sadlike:
  10. Sidhu88
    808
    76
    Get it sorted asap, it puts additional stresses through the suspension system when it gets really bad. If not u, then someone before u who had the car has been too heavy on the brakes too early (in transfer mileage or somthin?)
  11. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,886
    673
    I heard from an Aston Martin dynamics engineer that there's no such thing as 'warped discs'... He said that the usual cause is actually pad deposits on the disk and you just need to take it up to motorway speeds and emergency brake down to 10mph without stopping, then accelerate back up and repeat this so you end up braking extremely hard about 8-10 times until you can smell the brakes burning and then drive at a constant motorway speed for a few miles to let the brakes cool down again.
    I don't know if this is true or not, just passing it on. :)
    45bvtc likes this.
  12. S3Alex
    10,854
    4,841
    I think the stock brakes on the S3 are OK for a car up to Stg2,but given that the car weighs 1500kgs,as power rises,and speeds increase,it's pretty easy to get them way too hot,and encounted fade and possibly warping.
    Time for a chat with DaveB I think.
  13. Sidhu88
    808
    76
    It doesn't matter how much power u have. If they're not aligned correctly on install then thats the beginning of problems. If the driver is too heavy on the brakes too early thats another cause, when theres new discs and pads then thats when its more likely to happen if they're not worn in properly (personal experience)
  14. SootySport
    SootySport Well-Known Member Team Silver
    2,952
    786
    Sounds like a load of old Tosh to me.
    Assuming the braking components are aligned properly, discs wear according to how often and how hard you hit the brake pedal, the quality of the metal in the disc and the hardness of the pads. On a newish car you would assume all is as it should be. My guess is the quality of this batch of discs is not what it should be.
  15. S3Alex
    10,854
    4,841
    Absolutely.
    It just wasn't what I was getting at,as I'd sort of rambled a couple of stages down the line,and not seen how new the car was!
  16. Ben S3 8P3
    Ben S3 8P3 Member
    313
    32
    Ive got this issue with filling it. Never seems to be able to get full! Whats going on
  17. sliced
    sliced Drive safe, stay alive.
    1,571
    335
    ouch mine this has happened to my a3, but it was because some numpty lauched mine with the handbrake up :$
  18. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    My mate had the same prob on his 8L with about 3k on the clock...
    Then again he had gone from 120 - 20mph on full anchors!
    Replaced under warranty tho :)
  19. c_w
    c_w Well-Known Member
    1,169
    91
    Nope it's the truth. The vibration will 99% be from pad deposits causing judder. You can skim the discs to remove the uneven pad deposits and they'll be smooth again but if the same pads and braking style are used the vibration will likely come back. Or you can use a more aggressive pad that might clean the disc up.
    Brodster, What pads are being used?
  20. jaydav2306
    jaydav2306 Member
    217
    How long typically should discs last without any issues? I know i'm due new pads soon, mines done 35K
  21. The Governor
    The Governor Active Member
    528
    75
    I thought it was just me!
    It seems they don't like being filled while near full, I was going ona long trip today and thought I'd top it up (it was about 1/8th from full, I figured about £15 worth.
    It started clicking at £5, which I knew was wrong, nursed it to £8 at which point is started spitting diesel down the side of the car, so I thought maybe I had overdone it after all. Got it started up, and it's a good 1/16th off full.
    The fuel neck seems like it's designed wrong, I've had trouble filling up on other occassions too, when i never did on any other car I had.
  22. mjr901
    mjr901 Guest
    I brimmed mine from empty 2 days ago now, I got at least 40 miles before I saw any massive movement off the top.
    it was pretty much dead on £10 extra after the click.
    But to be honest, I hate driving it full of fuel, performance is reduced, it feels much heavier, well it is! Something roughly like 1kg= 1 litre.
  23. S3Alex
    10,854
    4,841
    Not quite that bad,but 60litres will add just over 40kgs to your car....I on the other hand,can add more....LOL
  24. mjr901
    mjr901 Guest
    Ahh I was mis-informed, still heavy stuff! :)
  25. S3Alex
    10,854
    4,841
    Not as heavy as what sits in the driver's seat!.....I think it's noticeable probably,but I tend to brim mine,then run it to near empty,and try to get whatever discount/points etc I can get from the local garage.
  26. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,081
    768
    15 miles and it moves off the full? i get at least 50 miles in my rs6 before it moves.
    i shake the car sometimes to get the air out the tank and it usually lets some extra go in.
    i did manage 150 miles from a 80ltr tank once :keule:
  27. The Governor
    528
    75
    I don't tend to get the "moving off full" problem (at least I've never seen it) but have had a few times when the pump just clicks and clicks.
    I have a sense that it's a combination of an odd fuel neck design plus a sensitive pump. I like to brim it each time, it makes it easier to monitor mgp...
  28. mike foster
    3,967
    Are we still on about warped discs or has the thread changed to filling-up problems ?? lol
  29. Brodster
    3,553
    896
    Twas a bit of both actually Mike.
  30. mike foster
    3,967
    Ok - have you got anything sorted ?
  31. Brodster
    3,553
    896
    Not yet. The discs are definately warped so will get them changed under warranty. The fuel thing I can live with. Im actually looking at selling the S3 due to getting a new dog next week and Im looking at the B7 RS4 for bigger boot space so just trying to find a descent one in the colour and spec I want......could be a long wait.
  32. mike foster
    3,967
    It's not a 'Scottish Border' terrier (or collie) is it ????? Sorry !! lol
  33. Brodster
    3,553
    896
    HAHAHA!!! No its not............its a Shiba Inu.
  34. mike foster
    3,967
    Sounds like a 4 wheel drive !!!!!!!
  35. Brodster
    3,553
    896
    It does doesn't it........they are basically a small husky.......small japanese wolf to be exact.
  36. mike foster
    3,967
    Well good luck with that mate !!
    Now we really are off topic - back to warped discs/tank filling !!!!! :icon_thumright:
  37. larsmate
    larsmate Member Team Tango Audi S3 DSG
    128
    9
    Absolutely true. This is why it is imperative that the brakes are bedded in before you stamp on them. The other cause is leaving your foot on the brake when the rotors and pads are extremely hot and not rotating which causes transfer of pad material to the surface creating high spots and in turn brake judder. If a rotor is warped, which technically is virtally non-existent, then the pads will deal with it anyhow by moving in and out - the disk is still flat and the friction isn't being altered. A mechanic will still call it a "warped disk" because they can't be bothered with the technical explanation.
    edit: PS -Warped- Brake Disc and Other Myths
  38. Gogadgetman
    Gogadgetman New Member
    My S3 is now on its 4th set of front brake discs and pads after they all warped after doing a couple of thousand miles on each set. The first 2 sets were Pagid which I fitted. The third set were from Audi fitted by my Audi independent mechanic. These have been replaced by Audi after my mechanic claimed on Audi's warranty. My mechanic did a full check on the front end of the car and so did Audi. The check included hubs and calipers and clean bill of health. The discs are not drilled of grooved so no build of pad material. They have no answers so I think its time to get rid of the car before they warp again. Hope you have better luck.
  39. 964kevin
    964kevin Member
    109
    I track my weekend car, and despite using it very heavily on its standard disks and pads have never had "warped disks" its all pad transfer. Which is why on a track day, one cool down lap, come to a rolling stop, and leave in gear, don't touch the brakes.
    If anyone can show me the TIR for a set of warped disks I'll change my mind, but as none of my colleagues nor I have had this, and we rack up a few hot miles, I'm in denial.
    K
  40. S3_Mat
    S3_Mat Active Member
    550
    192
    43
    Remaining stationary at lights after very heavy brake use will cause a temperature difference across the disc and can warp them as the pad holds the heat in. I use the handbrake as a matter of course or if the surface is flat no brakes at all at junctions after a blast.
