i've got 2 lights coming up on my dash, i've got the ABS light come on and a (!) starts flashing, is it just 1 of te ABS sensors gone or is it something else
It's a sure sign that the ABS system has a fault, only true way of finding the root cause is for a VAGCOM scan to be done otherwise you'll end up p&ssing in the dark changing things over.
A quick way of determining if the ABS sensors have gone awry is to disconnect at the plug and drop a multimeter across the terminals to check if there's an open circuit on the sensor
looks like i need to get myself 1 of these vagcom's, already got the op-com for vauxhall, was a nightmare to install on my laptop, some1 on here gave me a link to a cheap 1 on fleebay but i've seen some1 post on here that u need to watch out for the cheap 1's, c with my op-com 1 i have a lot of prob's with my antivirus an d i dont want that again
got 1 more thing, im not sure if my temp gauge is working, it never seems to move even when the cars just idling for 10-15 min, would the vagcom tell me if something is up here as well
Do the abs symbols clear if you switch ignition off? If you can start car and the warning only comes on once you drive off then it's maybe a sensor problem.Vagcom will show which one is faulty.
