Warning light on dash
redspudder Dec 22, 2008
  1. redspudder
    redspudder Sparky
    371
    I have today got a problem with the orange warning light on the dash showing i have a light out and writing in the red part saying "front dipped beam right "this came on once or twice last week and went away today it was on when i went to work and stayed on when i returned home and is still on now when i start the car the only problem is that i dont have a light out have checked all of them and had a quick look at the wiring and all seems to be fine any ideas what it could be maybe a sensor?I have rang a local specialist and told me he can do a diagnostic check for £35 to try and find the fault
  2. quattrojames
    14,045
    570
    Do you have HID's fitted?
  3. J7USS
    J7USS Shuddup Foooool!!
    3,731
    69
    Im getting this same fault too :uhm:but mine goes away when I adjust the level up and down!!
    I have Hids too.
  4. redspudder
    redspudder Sparky
    371
    No but i have have changed the lampsbut that was in August
  5. J7USS
    3,731
    69
    have you tried giving it a knock on the headlight and flick the level switch up and down few times!!
  6. redspudder
    redspudder Sparky
    371
    Ive just been out in the car and the fault is no longer there?this is confusing,i rang 2 places today one said it could be a number of things and could do a diagnostic check the other said it sounds like it could be the dashboard and that would be very costly i am prepared to run with it for now as it seems to be intemitent fault but is confusing me i am a sparky by trade and have done most checks on the light and cant find anything obvious wrong electrically although car electrics are different to what i usually work with but have tried things that i would normally and all seems sound
    :uhm:
  7. evilscotsman
    evilscotsman Space Cowboy
    1,350
    13
    the ecu has to be measuring the current through the lamp mate, since the warnings only show when the lamps are operated - so that rules out impedance testing. There can't be some kind of inductive coil pickup like we use on motors for stand-still current detection because its DC - I reckon the current down the wire is measured at source.
    That points to a fault at the convenience & lighting unit since the detection is likely done at the supply point, not at the endpoint of the circuit. The lamp could form the 4th leg of a Wheatstone bridge (in the ecu), the other 3 resistors are of known value and so the lamp current can be calculated from the total current in the circuit using the K-Law.
    If one leg of the bridge was open circuit, the lamp would still receive current to operate properly, but the bridge current would be wrong and trigger a warning.
