Warning Light on Dash
steveh Dec 24, 2005
  1. steveh
    steveh New Member
    29
    Hi,
    Driving back last night and an orange warning light came on which is shaped like an engine. Looked in manual but it doesn't say what it is but searching the forum I gather it is some kind of engine management light.
    This could not have happened at a worse time what with it being Xmas and I was just wondering if there were any thoughts on whether it would be Ok to drive or not?
    It seems to be running perfectly fine but concerned I will make things worse but really need the car over Xmas
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    if it is running fine, it could be the lambda sensor. If there is anybody near you with VAGCOM the could check it out and clear it depending on what it is.
  3. could it be the MAF sensor?- also a common problem.
  4. dickys3
    2,963
    23
    Could be anything to be honest with you.. Get it plugged into vagcom before you do loads of miles just in case.
    Could be something simple, but could be somethng a lot worse...
  5. steveh
    steveh New Member
    29
    Booked in for next wednesday so fingers crossed. The "nice man" /ubbthreads/images/graemlins/smirk.gif at the stealership seemed to think it would be Ok to drive and wouldn't be anything too serious. Suggested it could even be caused by something as simple as a change in petrol.
    We will see I spose but I am still not going to take a chance driving it
  6. steveh
    steveh New Member
    29
    Fixed. Turned out to be a faulty coolant temperature sensor.
    Have had a new one fitted for £89 so could have been worse.
  7. madvw
    madvw Active Member
    2,489
    £89!!!! wow.
  8. starski4578
    starski4578 Member
    150
    thats expensive cost me about £30 at awesome gti!!!
  9. god_thats_quick
    2,507
    I don't think that's too bad at dealer prices! Good to hear you got it sorted.
  10. necroeire
    necroeire Active Member
    1,008
    I appear to have the exact same problem. After I got the first indication I added a little more coolant and it stopped. It's reappeared again now and when I stop the car the fan stays running for a while longer. Service is due anyhow so I'll get the stealer to check it out.
    From the issues I've had over the past few months (door appearing opened on the dash, indicator relay box going twice, lamda sensor messing with the idle, etc) I'm beginning to think all these issues are almost seasonal related. Each time I get a problem I check the forum and lo-and-behold there are several others with the same problem at the same time.
    Either all these Audi's are in contact with each other or the build is not as bulletproof as we all once thought.
  11. madvw
    madvw Active Member
    2,489
    [ QUOTE ]
    Either all these Audi's are in contact with each other....
    [/ QUOTE ]
    I deliberatley don't park mine next to another audi (or even worse , between 2 audi's), just in case they cook up some kind of plan between them..
    for some reason its always the younger whippersnapper audi's with the problems, the older boys seem to be much better behaved..
  12. necroeire
    1,008
    Ha ha, either that or the older models are better built.
    These newer ones, still seem to have their teething troubles don't they.
  13. RichWalk
    RichWalk New Member
    23
    [ QUOTE ]
    [/ QUOTE ]
    You really dont want to know how much mark up there is on that price /ubbthreads/images/graemlins/shocked.gif
