Wanted - Rear shock for 96 1.8 N/A SE avant
Crombie Sep 9, 2009
  1. Crombie
    Crombie Member
    55
    Suspension ont ald avant started to have issues. Front springs split and just spotted rear shocks got a leak.
    Its a standard setup, if anyones got a decent used one/set lying around, live in Preston Northwest.
  2. Crombie
    Crombie Member
    55
    Update:
    Got front spring sorted just after used rear shocks.
    May have to broaden search, which B5's have the same rear shock fitted?
  3. aragorn
    18,609
    871
    If you got a matched pair for the rear you could use dampers from any FWD B5 before 1999.
    If you want an exact match though, you really need to look at 4 cylinder, Avant SE models.
  4. Crombie
    Crombie Member
    55
    Ok better stick with SE model I think.
    Front spring was an **** of a job to sort because pinch bolts seized, still unable to budge it, don't know what I'll do if any of the arm need replacing? Whilst I was messin about found out garage that did the flexi CV boot, used cable ties to fix boot on. Get me bow n arrow, knock his stetson off.
  5. aragorn
    18,609
    871
    Whats wrong with cable ties?
  6. Crombie
    Crombie Member
    55
    My experience they never seem to last very long, are they meant to be used with oil/heat/grease? In past redone couple of cars that had them fitted with metal ties! Not one of those jobs I like doing that often.
  7. aragorn
    18,609
    871
    i dunno, i've used cable ties plenty of times without incident, as i've never managed to work out how on earth those metal things work :p
  8. Crombie
    Crombie Member
    55
    Took me a while but figured metal jobs out, need one of them tools used once every couple of years and have to hold your tongue out to the left. [​IMG]
