Wanted:Front Drivers side Hub assembly/wheel bearing housing for 2000 1.8tqs
neilA4 Feb 7, 2010
Thread Status:
Not open for further replies.
  1. neilA4
    neilA4 Member
    211
    Has anyone got a spare front hub assembly? basically need the bit that all the ball joints connect to. Someone has put a different one on my car, including a smaller cv joint to fit the hub!! Bloody cowboys what next..
    part number will be something like this 8D0407258AE or 8D0407258AM. The correct one on the passenger side is 8D0407257AE.
  2. Broken Byzan
    13,237
    465
    Hi there i have in my possesion a set of uprights with 82mm bearings and matching CVs. Removed i believe from a 2003 Passat Diesel, i bought them in error
    Part numbers are 8D0 407 257 AR and 8D0 407 258 AR. Any use?
  3. neilA4
    neilA4 Member
    211
    not sure if those would fit mate, cheers anyway.
  4. Broken Byzan
    13,237
    465
    Ok no probs.
    Will retain them for use on my TQS
  5. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    ive got one but cant remember which side it is, will check for you tommorow
  6. aragorn
    18,369
    828
    Neil: i suspect Byzan's ones will fit just fine, the passat has B5 running gear, and they're the larger 82mm bearings so should slot streight on.
  7. neilA4
    neilA4 Member
    211
    maybee as a last resort i'll put one with a different part number on, just don't want to fit the wrong one cheers.
  8. olds_kool
    1,089
    13
    got drivers side ending in AE, was from my car as i fitted s4 ones and bearing is good, pm if you want it
  9. neilA4
    neilA4 Member
    211
    you have pm
  10. Broken Byzan
    13,237
    465
    All sorted, so closed. Thanks
Thread Status:
