wanted chrome exhaust tips
rasA4 Jun 18, 2007
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    im after a pair of chrome exhaust tips for my A4 diameter is approx 59mm, can seem to find any decent trims been to halfrauds had some cheap and nasty or some big boy racer ones also had a look on ebay. does anyone work in audi who can may be measure one up for me and get a part number?
    thanks in advance guys
  2. hiltoa
    hiltoa VAG erfahren
    298
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,016
    206
    How are these for you? The outside measurement of each tip is 76mm, bit bigger but maybe of interest!
  4. 205man
    205man Active Member
    1,072
    14
    rasa4 - ive been looking for the same thing for my 2.8.
    i did find a firm on ebay in the usa that had some proper ones to fit the 2.8 but by the time you bought them and the postage they became a very expensive option.
    my local custom exhaust shop said they could replace the tailpipes from between £50-£90 depnding on style, quality and size. this way they would cut the old pipes back and weld in the new ones
    i think this is the option ill go for until i sort out the proper exhaust so worht trying one near you
    alan
  5. rasA4
    3,287
    119
    thanks i was looking for a straight type if possible
    side view
  6. rasA4
    3,287
    119
    thanks but i have twin pipes already just need the tips
  7. rasA4
    3,287
    119
    thanks for the idea, however this sounds expensive esp after spending money on them then the exhaust 'goes' then having to start again
    im not asking for much some one must do them?
  8. Lowlife
    Lowlife German Hardcore
    568
    I got some from a local auto factor for about £9 the pair. One thing I would say is that if your pipes are slash cut you get a build up of carbon where the bottom of the trim doesn't meet the pipe, this results in black stains on the lower edge of the trim that you will forever be polishing off!
  9. Road Razor
    Road Razor Member
    411
    As I'm having a new rear bumper fitted next week I'm looking for a pair of exhaust tips - the standard ones just won't do. I'm looking for a similar type that rasA4 mentioned probably just like the one in the first link below.
    http://www.powerflowexhausts.net/products_details.cfm?partno=RI
    http://www.powerflowexhausts.net/products.cfm
    I probably be buying some locally.
    Note: To measure your exhaust its best to take a piece of paper and press it against the end of the tail pipe to make the rings of the shape. Then measure on the paper to determine the dimensions. I found that the standard 2.4 exhausts not circular, they're oval. Minimum diameter 63-64mm.
  10. Tonya Rosey
    Tonya Rosey Member
    Hiya there. Try www.longlife.co.uk . I am getting a S/S back box made, fitted and inc of VAT for £169. They make what ever design you want.
    Don't know where you live, but the nearest one for me is Leeds. They even offer you a courtesy car for the 2 hrs that your car is there!
  11. Hammy
    Hammy New Member
  12. rasA4
    3,287
    119
    thanks crash, do you know how much the first one goes for? how easy is this to fit does it have to welded?
  13. rasA4
    3,287
    119
    ive had these before however i kept the original screws and guess what one has fallen off it lasted for 2 years though
  14. rasA4
    3,287
    119
    thanks Tonya im no where near there anyway dont want to change the back box yet, just want the tailpipe trims,
  15. Road Razor
    Road Razor Member
    411
  16. rasA4
    3,287
    119
    i do like the daytona trim might just order these cant see the fixings on these i assume its usual screw in the existing exhaust?
