Wanted - A3 2012 in dash card tray
apoc_reg Apr 21, 2012
  1. apoc_reg
    apoc_reg Member
    66
    Anyone have one or know where I can get one?!? For some reason my brand new A3 just has the 3 spacers fitted.
    It's the one with a slant that fits on the right of a right hand drive car not he older rectangle one.
    Thanks for any help!
    Rich
  2. h5djr
    9,438
    1,757
    Funny because I've also got a new 2012 A3 SE Sportback and after seeing your post I had a look at mine. It dosn't have a coin tray either just the 3 switch blanks.
    I've had a look on the ETKA parts catalogue and it is still listed but for dates 07/08 > 01/10. The part number is 8P0 941 561J and the price is listed as £36.73 incl VAT. Whether it will fit a 2012 model I don't know.
  3. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    I've been lost without a coin holder on my 2012. Haha.
    I do think that row is slightly different in shape though.
  4. h5djr
    9,438
    1,757
    It's quite surprising the number of small changes between my 2009 A3 Sportback SE and my new 2012 A3 Sportback. Here is a list of the items I've noticed so far:
    1. Different gear-knob
    2. Different gear change action - with resistance
    3. Chrome door handles
    4. Optional 16-spoke alloys are single darker colour
    5. Different mirrors - smaller and fold better
    6. Different way of displaying gears in the DIS - D4 and M5 rather than PRNDS and list if numbers
    7. No coming home switch on lighting switch - changes made using DIS
    8. More change options on DIS - Lighting
    9. DIS option to show current/overall mpg/outside temp/radio on same screen
    10. Chrome edges to door windows switches
    11. Chrome knob to mirror changing switch
    12. Brightness of footwell lights adjustable using DIS
    13. Auto Start/stop system
    14. Grill and fog light surrounds now gloss black
    15. Extra chrome surrounds and strip for fog lights
    16. Badge on the back just says TDI rather than 2.0TDI
    17. No space saver - compressor and sealant instead
    18. No coin tray in centre console.
  5. Cruiser89
    1,484
    222
    Just going to your point 9. I know you have the Eco-screen which you can change to show different measurements. But is it possible to change the top half of the screen that shows radio/track info. Would be great to get MPG in there instead!
  6. h5djr
    9,438
    1,757
    Working from the top of the screen is shows:
    Radio station name or frequency or TP1,2,3 for track number if placing a CD. These are just normal CD, Not sure what it would show if they were MP3.
    Outside temperature
    total miles remaining or journey time
    overall mpg for journey
    current or instant mpg
    details of gear selected using s-tronic.
  7. apoc_reg
    apoc_reg Member
    66
    Cool I shall look at the list, cheers for the info!
  8. NHN
    29,399
    1,738
    Only way to get coin/storage tray is to fit the older MY09 console buttons etc as tray was removed from MY10 onwards, also note connections changed.
  9. apoc_reg
    apoc_reg Member
    66
    Cheers NHN, will look out for one!
    Rich
  10. Rob2k68
    Rob2k68 Well-Known Member Team Daytona VCDS Map User Audi S3 quattro DSG
    6,908
    10,351
    The newer console tray (MY10 +) has the switch holders heat staked to the back of it so that the switches clip in it rather than the older way which is to fit the switches in the dash then clipping the trim bezel around it - this is to achieve better alignment of the switches to each other and the bezel. I guess this could be dremelled away but then I don't know how the card holder would be supported.
    If you was to install the complete '09 MY unit then as NHN says, the switches are different as the newer unit looks to have one connector for stop/start and traction control combined. Could be a tricky one this .....
  11. apoc_reg
    apoc_reg Member
    66
    Cheers Rob
    i've had it out and looked and as you say its heat soaked but it is in two parts still so if i could cut away the side where the 3 spacers are it would come out and the tray would still work as it clips into the dash ok (I've checked).
    Its wether I could cut the plasic without ruining it!! Guessing a stanley knife wouldnt do it ;-)
    Anyone know a way of checking what a replacement MY10+ would cost me if I did ruin it...!?
    Cheers!
  12. NHN
    29,399
    1,738
    Dont even bother taking it apart, its not worth it, just buy 09 versions & sell your unit on.
  13. Rob2k68
    6,908
    10,351
    As NHN says that is probably easiest, less risk and you wouldn't be too much out of pocket. The only question is the vehicle harness going into the switches as later switches only have one connector ... ?
    If you go down the dismantle route I'd be inclined to try a soldering iron to melt off the plastic heat stakes - I have a scrap one I could send you to experiment on first just cover the postage.
  14. apoc_reg
    apoc_reg Member
    66
    Perfect cheers rob, let me know the postage and I'll transfer it over. That way i'll know if I should just do as suggestted and find an older version!
    Thanks guys
  15. NHN
    29,399
    1,738
    Your best bet is to heat up the flattened plastic & then prise the part away so it leaves a slight pillar as such so you can then slide something back onto it, should the need arise, heat up area & flatten it again.
    Harness is least of worries.
  16. apoc_reg
    apoc_reg Member
    66
    Could be interesting! :)
  17. Rob2k68
    6,908
    10,351
    I'll post it tomorrow Rich - just send whatever is on the stamp.
    Having looked at it just now the same posts that hold the blanking plate surround to the bezel also hold the spring clips in place so it could be tricky so best to have a play.
    All the best rob.
  18. apoc_reg
    apoc_reg Member
    66
    Thanks Rob, I'll let you know how it goes.... think i'll try soldering iron on one side and dremel on the other!
  19. apoc_reg
    apoc_reg Member
    66
    Success! Thanks to Rob for sending me the part to try, I ended up using that as it worked perfectly first time.
    now if only I could get it to light up too :)
    For anyone who ever wants to do something similar with the latest A3's this is how:
  20. NHN
    29,399
    1,738
    Well done, looks good.
  21. Rob2k68
    6,908
    10,351
    Awesome !! Well done Rich and nice write up.
  22. Gweev
    Gweev Member
    74
    I have a MY12 car too and want to try this mod, so thanks for the write-up.
