Want to fit and aftermarket headunit but keep amplified speakers.
pandoo1 Dec 6, 2011
  1. pandoo1
    pandoo1 Member
    93
    As above guys, what iso lead will I need to get? and I will also be fitting a sub and amp.
    Its for an 2004 8p1.
  2. pandoo1
    pandoo1 Member
    93
    Anyone got a clue?
  3. Ash187
    7,469
    728
    do you have bose?
  4. pandoo1
    pandoo1 Member
    93
    Im not sure tbh, ive just got a concert single din headunit.
  5. Ash187
    7,469
    728
    when you switch on the car does it say BOSE on the radio display? do you have BOSE on the front speaker grills?
  6. pandoo1
    pandoo1 Member
    93
    No no, none of that. But I have got a standard sub, well it sounds like one in my boot!?
  7. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
  8. Ash187
    7,469
    728
  9. AndyMac
    9,832
    45
    All single DIN HU's are ISO (not quadlock), so you'll need the ISO kit:
    Autoleads PC9-404 Audi Harness Adaptor (RCA, non-BOSE) £7.99 including VAT. PC9404. Buy discounted car audio online at In-Car Express
    But as you're fitting a proper sub you'll need to run an RCA & power cable so you'd be far better off rewiring the rear speakers to the HU and bypassing the Audi wiring altogether. Otherwise you'll have 2 x 50w+ going to the fronts and still have the feeble 2 x 20w going to the rears from the Audi rear amp. You can pick up the feeds for the rears from the connector on the Audi sub, so no need to dismantle half the car.
  10. pandoo1
    pandoo1 Member
    93
    Ahh thanks guys, do I definitely need to get that iso lead Andy mentioned?
  11. Naj
    Naj Member
    75
    Im a novice with ICE. I recently changed over my HU and only get sound to the front speakers. Can you elaborate on this abit more. Non-Bose also.
  12. Ash187
    7,469
    728
    Bose systems are all amplified off of one Bose amp.
    non Bose units have the fronts amplified from the HU and the rears off a small crappy amp like thing with the crappy plastic sub.
    if you change over the HU you would need to make sure you have the correct wiring adapters to be able to listen to the sounds properly from all speakers.
    Andy was saying as the OP is going to put in a proper sub and do away with the crappy plastic thing he may as well wire in the rear speakers to the HU directly and then run the new Sub via RCAs to the HU as per normal
  13. Naj
    Naj Member
    75
    Can I not just pick the rear speaker feeds from the Audi adapters behind the HU? Just don't wanna be pulling out interior panels to run new wiring from rear speakers to HU.
  14. Ash187
    7,469
    728
    in your case as you are just using a new HU and not playing with anything else i would guess that you are using the wrong harness adapter as it should have just worked. have a browse through the ICE section of the forum for similar issues as i vaguely remember seeing an issue like yours a while back.
  15. AndyMac
    9,832
    45
    There are no rear speaker feeds at the HU, that's the problem. You either buy an adapter that feeds the rear pre-outs (RCA's) into the Auid rear/sub amp loom or rewire the rears directly to the new HU. As already said you don't have to pull all the panels off as you can pick up the feeds to the speakers from the connector going to the sub
  16. moag
    moag she's no d-turbo
    821
    35
    Andy do you have a link for an amplifier adaptor that could be used with quad lock (07)? Is it possible to get one which incorporates steering wheel controls? I've had a look at auto leads and connect 2 but not sure which one i need.
    Planning on changing my rns for an alpine one unit in the next week or so
    non-bose btw :music:
  17. Ash187
    7,469
    728
    i think this is what you need
    CTSAD002 CAN-Bus steering control adaptor
    with the alpine bit
    Connects2 Alpine Stalk Adaptor
  18. Naj
    Naj Member
    75
    Do you know of the correct harness adapter to use for a 2004 non-Bose single din HU?
  19. AndyMac
    9,832
    45
    Yes the one I posted above PC9-404
  20. pandoo1
    pandoo1 Member
    93
    Theres one thing I dont get, why is there RCA's on it? I will be fitting an Alpine headunit.
  21. Naj
    Naj Member
    75
    Thanks, for £8 no harm in trying it.
