WALK, KMD HPFP, Spacers, Neuspeed P-flo, Rear ARB, Milltek Turbo Back, Eibach Sportlines
Dannyc87 Oct 27, 2013
  1. Dannyc87
    Dannyc87 Member
    Hi all, I have recently returned my 2010 Seat Leon Cupra to standard, and have a number of parts to sell. The majority of these parts are applicable to the MK5 Golf and A3 8P platform.
    All parts (aside from the Milltek) are currently located in Sydenham, SE London. I would prefer cash on collection from Sydenham, however can bring any parts to the PistonHeads Sunday Service a Mercedes Benz World on 10th November. The Milltek is currently located at my brother's house, a few miles from Mercedes Benz World, so collection from there only.
    If you are interested in any of these parts, please contact me at dancallear@gmail.com - I check this much more regularly than here!
    1.) 2.0TFSI Fuel Pump with KMD Internals - this has been used faultlessly for around 10k miles on a stage 2+ car. You will need the pressure sensor and pressure release valve from your existing pump. (£300)
    https://www.dropbox.com/sc/njgini349tj8t5a/hpBWeJh6Wn
    2.) 15mm Alloy Spacers with longer radius bolts. 5x112. Used for 1k miles max. Bolts to fit OEM wheels. (£30)
    https://www.dropbox.com/sc/ch1ith31kdnl7ud/xj6F5GUsJz
    3.) WALK kit - Whiteline Anti Lift Kit. Used for 10k miles - no signs of wear. (£120)
    https://www.dropbox.com/sc/o7jocjev4ba2v25/gZnxsuoHJa
    4.) Neuspeed P-Flow Induction Kit with custom heat shield (heat shield is for a Leon 1P only). For K04 cars only. Used for 10k miles. (£150)
    http://www.awesomegti.com/neuspeed-p-flo-kit-2-0t-edition-30-s3-cupra
    https://www.dropbox.com/sc/kyfoyy6dtt136si/IytGYJUfk4
    5.) Neuspeed 25mm Rear anti roll bar - Used for 5k miles - Looks new! (£150)
    http://www.awesomegti.com/car/seat/leon1p/neuspeed-rear-race-anti-roll-bar-golf5-6-jetta-a38p-25mm
    https://www.dropbox.com/sc/nc839s2a1c82gs7/ONt_QOymQ0
    6.) Mk2 Leon Cupra Turbo Back Exhaust (Milltek) - the cat back section of this exhaust is 100% Milltek. The front section, is a customised decat pipe, which was chopped and welded to incorporate a 100cel cat. My car passed its MOT last week with the exhaust fitted! (£500)
    https://www.dropbox.com/sc/c862t30gzrj3aoq/9bWxmTr73o
    7.) Eibach Sportline Springs - Used for 1k and then I went for coilovers to get lower! As new! (£100)
    https://www.dropbox.com/sc/bjyk20iz6f3uooi/7L6YK6rhat
    Thank you for looking, any questions, please ask.
    Cheers,
    Dan
  2. JimmyH
    JimmyH Active Member VCDS Map User
    374
    73
    How many spacers mate 4 or 2? If there's 4 PM me I'll take them.
  3. Dannyc87
    Dannyc87 Member
    Just 2 JimmyH.
  4. JimmyH
    374
    73
    £20? I'll take them dude? PM me
  5. Dannyc87
    Dannyc87 Member
    ***CORRECTION*** The spacers are actually 12mm, not 15mm! Sorry for any confusion.
  6. elrao
    elrao Member
    378
    Interested in the fuel pump, just need to read up on that brand of internals. Is it an easy fit with the internals in?
  7. Dannyc87
    Dannyc87 Member
    Yes, easy enough to fit, unplug a couple of sensors, remove two hoses and 3 bolts. There are a few guides around showing how to do it.
  8. elrao
    elrao Member
    378
    Is the pump a common part number across brands? Not other words is it exactly the same as the s3 fuel pump?
  9. elrao
    elrao Member
    378
    Looks like part number 06F 127 025 K is the stock pump on all 2.0 Tfsi s, assume that's what yours is?
  10. Dannyc87
    Dannyc87 Member
    Hi elrao - Yes, it is a common pump across the 2.0tfsi range - My brother essIII had an S3 8P, and I fitted new internals for him too.
    Here is a photo of the part number from just now:
    It is revision H, not K as it is off a 2010 car. Thanks.
  11. Muzza80
    Muzza80 Well-Known Member
    699
    337
    Hi mate, if you can get a quote on shipping for the RARB ill have it.
  12. turbonutz
    turbonutz Active Member
    421
    61
    Ya up for an offer of 100 deliverd in mainland uk for walk?
  13. Dannyc87
    Dannyc87 Member
    Will ship for £120. PM me.
  14. turbonutz
    421
    61
