W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    42 vote(s)
    58.3%
  2. Kawasaki Green
    30 vote(s)
    41.7%
  1. Westy
    Westy Well-Known Member
    17,442
    1,100
    What tools do people use to get at the mani to turbo nuts? I've got the easy one off with a socket, can get a spanner on the rear on but can't gat a turn on it. And as for the hidden nut under runner number 1 :banghead:
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Prawn's the man!
    What you need to do is buy a set of spanners and then grind them down to little twiglets and hope for the best.
  3. Prawn
    11,370
    3,234
    You’ve found the easy one with the socket, leave that done up, as it’ll hold the weight of the turbo making the others easier to spin off.
    The hard one for me has always been the back most bolt with the slotted hole, as access is very tight and the collector stops you getting much in there. For that one I use a cut down 17mm C-spanner with the head ground down to make it thinner in every dimension, as well as cutting it in half length ways. it does the job nicely, although I often need to use levers on it to get enough purchase.
    Believe it or not, the one under the runners is actually really easy if you remove your downpipe.
    Take the downpipe out, then use the two nut method to remove the top most DP stud from the turbo housing, and that gives you enough angular clearance (check me out with my fancy words) to get a regular C or Ring spanner up under the runners and onto the nut. Oddly, despite looking the hardest, it’s easy with the top stud removed. Leaving the top stud in makes the angle too tight and a spanner won’t go in :)You’ve found the easy one with the socket, leave that done up, as it’ll hold the weight of the turbo making the others easier to spin off.
  4. badger5
    9,374
    1,916
    what did you use to put it on?
    is it a stud nut combo now?
  5. Westy
    17,442
    1,100
    Fitted it all when the engine was out! It is stud and nut combo. I can get a bent spanner on the hidden nut but I don't have the leverage to loosen it. Might have to remove the DP to get room!
  6. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    good look westy hope u get it sorted pal.
    ill be fitting my turbo to the mani and head with water and oil lines on first then as im using stud and nut combo.
  7. Westy
    17,442
    1,100
    My main issue is I don't have the right tools and I'm in the middle of nowhere. Going to see if the local garage has anything.
  8. superkarl
    superkarl MAN OF STEEL
    9,371
    2,368
    undo your dogbone mount and see if you can leverage the engine forward and support it there to give you a little more room.
    every little helps.
    and best of luck. wish i could lend a hand
  9. s3gazz
    1,376
    99
    westy if worst comes to worst can u not get it as tight as just to get u home then do a proper job if it dont course harm
  10. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Sheesh man, I was following the thread the other day thinking well done mate you've cracked the 300 mark and now this, don't let it get you down and hope its a quick fix!
  11. Westy
    17,442
    1,100
    It's at home now mate in my garage and I've stripped it down to try and get at the mani bolts but I'm close to giving up! I don't have the tools to grind down spanners so I'm a little stuck. Also the bloody prop shaft just makes this job so difficult :(
  12. <tuffty/>
    20,847
    3,687
    Not the best time to start your head gasket collection although you still have some way to go to beat Welly...
    I am going to replace the head bolts with ARP ones next time mine is off.... gaskets are cheap enough but replacing headbolts every time is heart breaking
  13. s3gazz
    1,376
    99
    i feel for u pal iv not atempted fitting the turbo to mani yet but ill be giving ago some with water and oil lines attached.
    i carnt say if the v3 mani is any different where the nuts and studs are involved but ill post up some pics when done
  14. BuuBBa
    BuuBBa Member
    133
    Friend of mine had engine destruction and talked with guy from JNL racing, and he said:
    "Not fan of arp's on 1.8t engines they lift with too much ignition timing. I have another customer that had build his engine himself runs 9.8 quarter mile times. He had cyl 3 crack as head lifted on arp from too much ignition timing on race fuel. Before then running less power with stock fuel and using nitrous and ran like that for 2yrs. Race fuel was fine on dyno then 3rd quarter mile run and bang. So he's now dropped engine to me to build."
    I assume that the head expands (aluminium) but the block doesn't (cast steel) and that would cause that..
  15. badger5
    9,374
    1,916
    or just bad tune it sounds like
    too much cyl pressure is too much cyl pressure, end of..
  16. 16Klappe
    5,795
    1,183
    I'm thinking that, surely if det is causing head lift it would mean it's not been timed and mapped right. :readit:
    "Before then running less power with stock fuel and using nitrous and ran like that for 2yrs." just screams to me that somebody who didn't know what they were doing mapped it for high octane and NOS.
    Sense that does not make.
    Any news Westicles? Or is your beautiful face buried in the bulkhead actually doing some work?
  17. Westy
    17,442
    1,100
    I've given up mate. I need to drop the car somewhere to do the mani for me cause I don't want the ballache! I might as well buy a V3 mani and all the bits I need and dump it all of at a garage. It's either that or I sell the thing.
  18. Prawn
    11,370
    3,234
    haha. you can't sell it. that's defeatist.
  19. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    One little thing and you're thinking of selling it already?
    What happened to you?
    House ownership made your soft or was it the kittens?
    Fix the damn thing and come back stronger and harder.
    You don't seen Prawn selling up after his little crash, Paul selling up cause...........I don't follow his thread that much but you get the point.
  20. Reesy
    Reesy Well-Known Member VCDS Map User
    3,639
    148
    As I said earlier, stop being a bellend.
    It's not like it's blown up, it's a *** manifold issue.
  21. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    nor when i fully rebuilt my engine got it back together then it dropped an exhaust valve after half an hour of running.
    there is no way you can sell it ! we wont let you.
    but if you do want to swap for an a3 with no problems other than a knackered lamba sensor you know where i am ;)
  22. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Freddo dont give up, im changing my bleeding gasket once a month!!
  23. ScottD3
    15,161
    1,121
    And that takes him 6 months.
  24. s3dave
    10,110
    736
    cnut...
  25. Westy
    17,442
    1,100
    My issues is I'm 50 miles from work with no spare car, having to borrow a family members car for the rest of the week. I don't have the expendable income I had before I bought a 4 bed house and my gf is starting to get fed up with the grief too. A V3 mani and all the parts needed to remove the head is goin to set me back another £400 on top of the £400 I spent last weekend. Just can't be arsed with the hassle at the moment.
    I'm currently weighing up my options!
  26. ScottD3
    15,161
    1,121
    Shove the S3 in the garage.
    Buy a TDI and save up for it.
    You're in the same situation as the rest of us who only has one car and lives on our own.
    Man up and deal with it dude.
    Its not the end of the world is it?
  27. Prawn
    11,370
    3,234
    You don't have options.
    Fix it.
    That is all!
    coatesy likes this.
  28. Westy
    17,442
    1,100
    You don seem to be listening! A cheap TDI will still be £500 to buy a shed then I've got to insure it and tax it and what's to say that won't have issues too! I could have dealt with this if it was 6 months down the line but as its been 2 days after a £400 remap I'm a little fcked.
  29. aragorn
    17,956
    701
    Harsh reality time.
    Didnt you think of these issues when you were going down this route? You've used a manifold thats known for cracking, and have an absolutely maxed out turbo installation... When you max **** out, it breaks.
    You either a) accept that it might break but its worth it and/or have a second car you can fall back on when it does, or b) realise that you rely on the car to do 100miles a day, have responsibilities (ie life/house/family/GF etc) and build the car in such a way that its reliable and lasts.
    Now its broken and your throwing your toys out the pram and saying your going to sell up, no doubt losing thousands of pounds that you've shovelled into it so far... Clearly you need to step back and approach this with an adult head!
    Cheap solution:
    If you have no money, refit the standard manifold, and unplug the N75.
  30. ScottD3
    15,161
    1,121
    I am.
    £500 for a shed?
    Damn, I use to pick up sheds for £50-£150. drive them for 6months, if they fell apart or failed the MOT, scrap it and buy another one.
    While my Car/s was in the garage getting work done to them ready for the time I had the money to get them back on the road.
    Spend a little now and save more in the future or something like that.
  31. Jason.s
    Jason.s Active Member
    2,879
    348
    Why dont people chip in a few pence and go round his house and we all smash the new manifold on in time for ADI instead of drive him into further car related depression lol. Im already doing what i can on parts so its just someone to help do it so Westy doesnt crack out the meth and matches.
  32. Reesy
    3,639
    148
    Look on the brightside Fred, at least you have rifle drilled rods.
  33. 16Klappe
    5,795
    1,183
    I've got a great solution Westicles.
    I've got a lovely A3 on the drive at the moment, with £500 spent it'll have the same power to weight as your S3 and will probably wipe the floor with it. This ones got ESP too; so no complaints about not being able to put the power down.
    You're going to have to take a K04 off ANYWAY, so I'll give you the A3 and the £500 for you to buy the K04 setup off Aaron. And you can give me the S3.
    That way everybody's a winner, I'd be doing you a favor in reality.
    x
  34. ScottD3
    15,161
    1,121
    I got some crystals.............................Not what you mean?
    I can only offer hugs, reach arounds and pasties for him to smash at ADI.
    I would offer spanner time but I'm to far away and I have a job to do.
  35. s3dave
    10,110
    736
    Bizzare....:think: With the ESP Jardo it will bog down faster than a nuked submarine...:)
    frenchman likes this.
  36. Reesy
    3,639
    148
    Throttle is analogue not digital as Prawn would say.
    (Even though he has a switch on his car so it doesn't run full power :p)
  37. 16Klappe
    5,795
    1,183
    Word, it's ****.
    Come on Westy, get it sorted or my sig will become a self for-filling prophecy. If you sell it then you'll never be able to say you beat me, and I'll continue to say that I'm quicker than you. It's a matter of pride; you've got me on the ropes now and just need to deliver the knock out punch. If you don't do it there's plenty of people waiting to take your place ;)
    ScottD3 likes this.
  38. ScottD3
    15,161
    1,121
    What ever happens, can I have your calipers?
  39. s3dave
    10,110
    736
  40. coatesy
    1,920
    280
    you cant do that iv already offered him my a3 for swap.
