W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    42 vote(s)
    58.3%
  2. Kawasaki Green
    30 vote(s)
    41.7%
  1. Westy
    Westy Well-Known Member
    17,443
    1,103
    Ok I think I have a fully working WMI kit now! I took the nozzle out the FMIC hose and pressed the test button, working fine.
    I fitted the inline filter, hit test, nothing! Removed filter, hit test, nothing! How can this be?!
    I removed the whole nozzle/check valve assembly off the hose and tested again, fluid coming out. Added the filter, fluid coming out still. Popped the nozzle back on, fully working! Bloody weird.
    I can only imagine that they have tightened this latest nozzle a bit more as I keep complaining they leak. The pump must not be able to crack it open every time!
    I'll be keeping a close eye on this little bugger. Might need to do some logging of AITs to be able to tell when it's working or not.
    Anyway, I had to destroy the old nozzle as normally AEM ask for the old one back bu as they are in the states they ask the uk customers to smash them up. I took it apart first and got some pics. Enjoy:
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You could have "forgot" to do it and had spares..... ;)
    Look forward to the logs...
  3. Westy
    17,443
    1,103
    No mate te keep bloody pestering me for pics, no joke. Anyway who wants a spare leaky check valve?! I don't know for sure that tightening it would have fixed it.
  4. dre_S3
    dre_S3 Member
    756
    39
    Lol really, they want pics :wacko:
    Hope it's all sorted now seems to have been a bit of a mish
  5. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    I was going to try and hang on to mine and just put a solenoid on it that opens with the pump coming on and possibly have 2 nozzles but after the 4th or 5th email I gave up and broke it with a hammer ;)
    The one you've got pictured is different to both of the ones I've had as both of mine had brass internals with a little wire mesh filter? Maybe you've got a complete different revision that looks to be made out of some form of nylon or plastic?
  6. Westy
    17,443
    1,103
    The little brass mesh bit is still there but it's part of the actual nozzle. My issue was always with the check valve part.
  7. Prawn
    11,413
    3,302
    was going to say, i'm sure mine doesn't have that plastic bit inside either :S
    I took it all apart when i got it, and as Stacey said, all brass internals and a gause filter inside too.
    Can't believe they pestered you both for pictures of it broken!
  8. Westy
    17,443
    1,103
    I just hope that my problems are now over. In 9 months I've had 3 check valves and 2 controllers!
  9. Prawn
    11,413
    3,302
    pretty horrific luck westicles.
    I'm so jealous of anyone with an engine right now :(
  10. Rosso TT
    Rosso TT Member
    146
    Same here, the nozzle on my AEM kit is made out of stainless steel of some sort.
  11. Westy
    17,443
    1,103
    I've had a horrible day of brake changing today! Spent 3 hours changing the discs and pads on the drivers front wheel! Passenger side took me 45 mins.
    Basically the Boxster callipers are a pita. The disc for the Boxster is 1mm thinner then the S3 disc so it's photo ally impossible to fit new discs and pads at the same time as they won fit.
    In the end I had to use the old inner pad with new out pads and a new disc. I'll have to wait till the disc and outer pad has worn a bit before I can fit the new inner pad. Not an ideal situation!
    Didn't even get a chance to do the rears so thatll be a job for next week but they will be easy. Then I can bleed the whole lot ready for ADI.
  12. s3dave
    10,110
    736
    Did you try without the shims.....:sly:
  13. Westy
    17,443
    1,103
    I ripped the shims off mate. There was no chance of them fitting.
  14. s3dave
    10,110
    736
    Is this a known issue then with your set up? maybe a heads up in the stickies?
  15. Westy
    17,443
    1,103
    I've always changed discs or pads separately. It makes sense that they won't all fit together if you think about it. My discs have only lasted 10 months and my pads 12 months so I just need to stagger them in future.
  16. Westy
    17,443
    1,103
    I think I've effectively driven 50 miles this morning with the brakes on :faint: The pads are in so tight that I'm sure there is a degree of rubbing, will probably end up warping my discs. Lesson learnt I think.
  17. Dani_B19
    9,109
    346
    Could you not get the pads slightly skimmed to allow fitment of both disks and pads at the same time?
  18. Westy
    17,443
    1,103
    Probably but it's hassle and not something I was expecting to do yesterday afternoon :(
  19. Prawn
    11,413
    3,302
    Do what andy and I did, drive along and get Tam to lean out of the passenger door rubbing the pad on the road. soon wears them down!
  20. Westy
    17,443
    1,103
    Haha that image was the first thing that sprung to mind yesterday :)
    I will see how they bed in and then I will either have to change a separate intervals in future or sell the callipers and go for some bigger ones.
  21. aragorn
    18,019
    716
    Just take a file to the pads. I did it just the other week to remove a ridge that had formed, worked perfectly.
    Not sure what the issue is though, theres usually way more than 1mm of slack in the caliper with new pads fitted to new disks...
  22. Westy
    17,443
    1,103
    Did you ever get boxster brakes Kev?
    Trust me, even with the callipers all the way in there was no way I could fit new pads and a disc in.
    I need to purchase some files anyway so I'll attack them later.
  23. Westy
    17,443
    1,103
    Car is now booked in for it's custom map.
    Booked in with RTech 1st week of October so it will be ready for ADI :yahoo:
    The end is in sight :ninja:
    Broken Byzan likes this.
  24. [Dave B]
    [Dave B] Daddy
    2,027
    145
    :w00t: for map.
    :( for the end being in sight. It's good to see the story continually unfold!
  25. StaceyS3
    2,489
    473
    Launch control??? ;)
  26. firestorm
    firestorm Member
    371
    Westy, what combination of pads & discs are youusing ? Boxster S or Boxster front calipers?
  27. Westy
    17,443
    1,103
    At the moment I'm running cheap stuff as I need to cut down my spending a bit. Got plain pagid discs with ferodo road pads and RBF660 fluid.
    Oh and they are non S Boxster callipers.
  28. superkarl
    superkarl MAN OF STEEL
    9,404
    2,378
    ... and flat shift.
    FTW
  29. Westy
    17,443
    1,103
    No and no.
  30. superkarl
    9,404
    2,378
    fag
  31. firestorm
    firestorm Member
    371
    I'm afflicted with that disease too. Way too easy to spend money on shiny or greasy bits for the S3. Mine was supposed to be a sensible station car. I've already spent £1k - still needs bodywork and a remap as a minimum, thats another £800 ish. Also thinking of polybushing the car, so thats another £600 (£280 bushes+£220 fitting +£120 4WA) and after that a FMIC and downpipe. At this rate I would have spent more on fixing it than what I paid for it.
  32. Westy
    17,443
    1,103
    I think I've gone way past that mate! If you read my whole thread you'll see I've spent a small fortune and compared to some I've not gone too mad. The custom map in a few weeks time and a new set of alloys are the final touches. I'll then hopefully calm down for a bit.
  33. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    That's what they all say!!!! You'll be back with something new to spend your money on.
  34. Westy
    17,443
    1,103
    I have mate, it's called a 4 bed house! ;)
  35. StaceyS3
    2,489
    473
    Dans looking at garrett/k04 hybrids and a possibility of bigger AR housings it could all happen ;)
  36. crazy88
    4,939
    437
    House FTW! Although angry Karl will no doubt come hurl abuse at you soon.
  37. Westy
    17,443
    1,103
    Just changed my rear pads and discs as they've not been done for 2 and a half years and I think it was safe to say that they probably didn't need doing.
    New Vs old
    And the disc was fine too:
    Just as has been said before this just goes to show how little the rear brakes do! I'd love a way to be able to adjust the bias to apply just a little more braking to the rear.
  38. Westy
    17,443
    1,103
    Small, small update.
    As the team dynamics group buy has stalled I had to find some wheels for ADI and Bedford Autodrome in November. I found these little beauties on ED38 for £100. They're TT wheels painted BMW imola red. Will look wicked as lairy track wheels plus I think red was a popular colour in my poll at the top of this thread.
    I know they're not lightweight or to the width and offset I wanted but I know they'll fit and I can stick my yoko slicks on them. Anyway here they are:
    StaceyS3 likes this.
  39. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    Dam 100 quid you jammy get ! I love them wheels for some strange reason
  40. Westy
    17,443
    1,103
    Yeah I seem to have a habit of finding bargains ;)
    I like them too. Maybe a bit too much for the road but they will be mint on track.
    Remap next week so some exciting things coming up in this thread I hope.
    StaceyS3 and coatesy like this.
