W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    43 vote(s)
    58.1%
  2. Kawasaki Green
    31 vote(s)
    41.9%
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    I'lll keep my eyes out.
    Got till AITP for me to bring any thing up to you.
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Haha cheers mate.
  3. Prawn
    11,677
    3,677
    not if I find it first you filthy devonian!
  4. Westy
    17,443
    1,105
    You should sell me a set of your track wheels you whore :moa:
  5. ScottD3
    15,165
    1,124
    Who?
  6. Sam_
    Sam_ Down under
    3,038
    480
    But it's only wafer thin spacer
    Stop worrying :p
  7. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    stop being a vagina, the weight a 5mm alloy spacer will add is no more than my left testicle.
    dare i say this but, dont halfords sell little cheap spacers like that?
    everyones after 17 x 8 wheels now!
    and prawn, you can stop whoring for once and let us have some!
  8. BuuBBa
    BuuBBa Member
    133
    How much one wheel and/or wheel + tyre weigths? 1mm of (aluminium) spacer weights about 40 grams so You can calculate with that..
  9. Westy
    17,443
    1,105
    It not just about the weight of everything. A spacer is changining the position o the wheel and effects the feel of the steering.
  10. Jason.s
    Jason.s Active Member
    2,879
    348
    Plus add in a set of longer bolts even for a 5mm slip on spacer..My front wheel fell off (thankfully only doing like 15mph) with running normal length bolts and 5mm slip ons due to only catching about 3 threads on each bolt. Never again!
  11. Westy
    17,443
    1,105
    Oh and you've just reminded me. These wheels are multi drilled so they don't use normal wheel bolts! They are thin head bolts that require a spline tool to do them up. Trying to get these bolts made up to be the right length for spacers too just isn't going to happen. I think I'll get these wheels on eBay :( the hunt continues.
  12. ScottD3
    15,165
    1,124
    What a ****ter mate.
    I'll keep looking.
    Give them a good clean and some paint on the curbing, try and get more than you paid?
  13. BuuBBa
    BuuBBa Member
    133
    Anyway, what is the weight of the set? Just curious..
  14. Westy
    17,443
    1,105
    Should be able to double my money without any work to them to be honest. I'll get the tyres removed, clean them and bang them on eBay.
    Depends on thickness of spacers but around 5kgs for a set of 4.
  15. BuuBBa
    BuuBBa Member
    133
    Sorry, ment the wheel + tyre or just wheel weights..
  16. Westy
    17,443
    1,105
    The standard 17" Audi S3 Ronal wheels are 12kgs each without a tyre. A tyre can then add an additional 10kgs per tyre depending on how much tread is left on it.
    The wheels I am looking for are OZ Superleggera (7.2kgs), OZ Ultraleggera (7.7kgs), or Team Dynamic Pro Race (8.9kgs). These wheels are all under 10kgs each without a tyre so there will be a significant weight saving which does make a difference to acceleration, braking, and handling.
  17. BuuBBa
    BuuBBa Member
    133
    Yep, I know.. Stock S3 17" + 245/45 Pirelli summer tyre was 24 kg, my winter wheels (Kosei 7.5x17") + 225/45 winter tyre 21.5kg and current summer setup, 8x18" Ultraleggera + 225/40 Hankook 18.3 kg. Really made difference for handling! Also the tyres can have almost 2kg difference between manufacturers and models in same size.
    Joeyburton17 likes this.
  18. Sam_
    Sam_ Down under
    3,038
    480
    Are they the right ET to start with though? I'm on ET20 8.5's on the front and it's pretty damn good. Better than 8" ET35 or whatever the S8 reps are.
    Spacers are only a problem really if:
    a) They're not properly installed (not enough thread (bolts too short) or not torqued correctly) or;
    b) They're ****e cheap ones that don't stayed centered (and so result in vibrations)
  19. Westy
    17,443
    1,105
    Out of interest does anyone know what ET I can run with 8J wheels? Will ET38 clear 4 pot callipers and the suspension?
  20. Westy
    17,443
    1,105
    The wheels I have were advertised incorrectly as 8J ET35. If they were 8J then they would clear my callipers. Because they are 7.5J I am buggered unless I use spacers. Due to the wheels being multi drilled they use thin head wheel bolts which require an internal spline to do them up. This will mean getting special bolts made up for any spacers I get so it's a big waste of time and money really.
    I'm not looking at other options and I will sell these wheels.
  21. Sam_
    Sam_ Down under
    3,038
    480
    It's not the ET, more the spoke design, when it comes to brake clearance. As I've found out recently. Not sure on the clearance suspension wise but 8.5" + 225 at ET20 is near enough flush with the wing...
  22. Sam_
    Sam_ Down under
    3,038
    480
    Ah good call. The OZs and Team Dynamics rims are pretty nice. I'd go those on mine if I bought again. A set of 10" BBS CH rears just came up for sale here mine you heh
  23. Prawn
    11,677
    3,677
    NO NO NO NO NO NO NO.
    If you're looking at what I think you are, the TD 'off the shelf' wheels, then forget it.
    Call Rimstock direct. tell them you want PR1.2's for trackday / motorsport use, and they will make you a set, to what ever width, offset, pcd, and centre bore you want.
    The off the shelf rims are all in **** sizes, and use spigot rings. Call rimstock direct and get exactly what you want.
    Considering most people run RSTT's with a 15mm rear and a 10mm front spacer, I'd be looking at getting some 17x8's in ET20 or 25 on the S3
  24. Westy
    17,443
    1,105
    Well that defeats the point of trying to get some "cheap" track wheels. I dont want to be spending £600 for the rims when I only get on track now and again. I might be better off just popping my yokos onto a set of standard S3 wheels again.
  25. Prawn
    11,677
    3,677
    £100 each + the VAT from Rimstock mate so not THAT bad, but I do see where you're coming from.
    if it's second hand wheels you're looking for, forget PR1.2's entirely, off the shelf sizes are 17x7 et38 only in 17's, which would be ****e beyond beliefe on your car.
    havn't you still got your S3 wheels?
  26. Westy
    17,443
    1,105
    What if I found some 17x8 pro race 1s ET38? ;)
    I sold my S3s a while back. I will keep my eyes open for some lighter wheels that will fit straight onto my car.
  27. Sam_
    Sam_ Down under
    3,038
    480
    Nothing wrong with a spigot ring really though, if you plan to sell the wheels on later to be used on a car with a larger center bore then it's helpful. They're not really a negative. Really all they do is distribute load if a wheel were to come loose at some stage. Instead of failing sooner, you get a vibration and get a warning and with conical wheel bolts/nuts its less of an issue.
    That said, 57.1mm (S3/A3) is seemingly the largest centre bore size for a 5x100 bolt pattern so you should be fine if you want to sell them on later.
  28. Prawn
    11,677
    3,677
    in a track use sitation, I'd say no spigot ring is always preferable to having one, whether it SHOULD make a difference or not, I just think it's better without.
  29. Sam_
    Sam_ Down under
    3,038
    480
    Fair enough. I know a couple of guys that compete using them but I guess it's personal preference.
  30. Westy
    17,443
    1,105
    I think I'm going to forget wheels again for the short term. I think Prawn has the best idea. I can contact Rimstock and they can make me any size and offset combination I want of the Team Dynamic Pro Race wheels for around £100 a wheel. They even do them in green out the box so I wouldn't need to refurb them.
    In the mean time I think I need to get my engine work finished. I'm currently getting prices for Genesis/Bosch 550cc injectors and adapters then I'll be looking for a mapper.
  31. Sam_
    Sam_ Down under
    3,038
    480
    Good lord! They're not shy!
    You might have more luck finding 630cc - there's always loads floating about on VWVortex.
  32. Westy
    17,443
    1,105
    630s will be a little too big for my little K04 plus I think they are harder to map in for idle and low load.
  33. <tuffty/>
    21,899
    4,206
    630 dekas are fine low load and idle wise (you would defo need a custom map though as your revo can't be tweaked for them) but 550's @3bar would be nicer... the spray pattern on the Bosch 550's seems to be nice and have a bit better atomisation than the 630's... my 630's run sweet as now I have tuned them in right :) and have done loads of bosch 550cc maps so loads of data available to get them running nice
  34. Sam_
    Sam_ Down under
    3,038
    480
    Don't want scope for extra later then? ;)
    That's certainly true of the older low impedence Bosch injectors but more modern designed injectors can often be mapped to idle as well, if not better than stock. I have a mate in the UK that runs 1000cc on his evo fq and the idle was better than my stock S3 :) The problem is it takes longer to map those conditions of course so it's often missed. I had my old N/A engine mapped a few times until light throttle and idle was spot on. Flat out is the easy part :)
  35. Westy
    17,443
    1,105
    I was under the impression that i'd require a custom map no matter what injectors I changed to? Surely my Revo Stage 2 map doesn't offer enough flexibility?
  36. Westy
    17,443
    1,105
    That was the original plan but after seeing what my car is capable of at the moment unmapped, I'll be happy on the K04. Realistically I don't think I'll be able to afford a big turbo any time soon after buying a house and needing to decorate and grow up :)
    My K04 is currently scaring most hybrids and 1 BT comes to mind too ;) If I get my way and end up stripping the interior to save some weight then this car will be very capable indeed.
  37. Prawn
    11,677
    3,677
    then when you DO bang a hybrid on there it'll be a proper monster! hahaha.
    Get 550's dude, capable of running your ko4 nicely now, and a hybrid later on down the line.
  38. Sam_
    Sam_ Down under
    3,038
    480
    Ah man, I'm going to have to grow up at some stage too and buy a house (not here!).
    Yeah I must say that's an awesome time for a K04. I'm not sure how the guy here got a 13.7 on an otherwise stock stage 1 k04 + dv! He's super human.
    I'm only going GT2871 because he's gone Precision 6262 (massive), otherwise I'd stick with the K04 too for a while I'm sure before a GT30 or something. It's quick enough for me most of the time!
  39. Westy
    17,443
    1,105
    Any spare cash I once had to put on the car is now going on paint and wallpaper for the house :(
    If, like Tuffty said, I can get my stage 2 map to accommodate 550cc injectors then I could have this finished quite soon.
  40. Prawn
    11,677
    3,677
    Isn't Welly running monster injectors scaled to work on his ko4 hybrid map still using uni settings?
