W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    42 vote(s)
    57.5%
  2. Kawasaki Green
    31 vote(s)
    42.5%
  1. stuartyj21
    stuartyj21 Member
    37
    stripped and ripped, liking the plans...
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Looks alright. 7.5" variety? The gf has those on the Leon. Lighter than my a4 wheels :(
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Yes matey. These are still quite a heavy wheel. The plan is to get some that are around 8-9kg per wheel.
    They feel so much nicer then the 18s. Not as harsh and the steering feel is much better without PCD adapters. They might not look as nice but I'm happy with them.
  4. Prawn
    11,609
    3,590
    they didn't come off Troopas car did they Westy?
    Looks nice, so different for just a change of wheel colour!
  5. Westy
    17,443
    1,105
    No they didn't mate. I bough them from another ASN member who had just bought a TT withthem on and didn't like them.
    A set of wheels really changes the look of a car. That pic above doesn't really do them justice as it's on uneven ground and I'd only just lowered the rear from the jack so it was a bit high.
  6. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    wheels look good matey, the colour suits the car way more than I expected to.... goodbye Avus III leader :bye:
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Defeatist.... lol.
  8. Westy
    17,443
    1,105
    F U man ;)
    I tried to plumb it back in the other day and I couldn't be *****. Think I'll just pop the resistor on :whistle2:
  9. Welly
    10,696
    129
    That's better :thumbsup:
  10. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Weren't you going to sell your car because you couldn't find a clunk?
  11. Jason.s
    2,879
    348
    ooooh fight fight fight.
    Keep it out and anything else that doesnt matter..weight loss ftw!
  12. Westy
    17,443
    1,105
    I'm all for weight loss and I can even deal with some less important errors in VCDS but I dont like the CEL coming on :(
  13. Jason.s
    2,879
    348
    Need the retarded ECU in our early cars. I pulled the carbon cannister sensor off and left the open plug expecting the light to be on like everyone said it would. Nope nothing lol. Just have an airbag light staring at me currently from no rear belts and bucket seat. I thought it would always annoy me before i did it all but you get used to it and zone it out of your field of vision.
  14. Westy
    17,443
    1,105
    Thing is with the CEL is you want it to be off so that if you get a real issue you'll know about it.
    You'll need to sort the airbag light or you wont get an MOT!
  15. Jason.s
    2,879
    348
    With my MOT testers i`ll be fine ;)
  16. Westy
    17,443
    1,105
    I'm glad you mentioned that as I'll need a new friendly MOT place when I move up your way :friends:
  17. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Westy.
    Sorry to go slightly off topic on ur thread but not sure where else to throw it.
    Ur ultrasonic cleaner. Is it a specialist piece or can u just use any available (subject to bath size) an what solution do you use when cleaning engine components?
    Cheers mate.
  18. Reesy
    3,640
    148
    You can use pretty much any available mate. I think the Silver Fox uses one from Maplins. I think he used the accurate measure of '1 squirt of Fairy Liquid' when he cleaned my FPR and injectors.
  19. Westy
    17,443
    1,105
    Correct young man. Maplin do one for around £25. It's meant for jewlery cleaning but it'll clean anything, including injectors. You can buy some solution from maplin too which is just a couple quid.
  20. Prawn
    11,609
    3,590
    fairly liquid is bad news! it's corrosive and will eat the rubber in the seals.
    Use James SeaClean solution, or just warm water :)
  21. g60leigh
    1,674
    207
    Thanks for the advice guys. I'm planning on picking one up for cleaning the injectors :)
    Guess it will do anything providing it has no electric circuits etc on it. Or can I get a alcohol based solution to do them?
    Cheers all!
  22. Westy
    17,443
    1,105
    Up to 414 miles now and so far so good. Been driving it quite hard this weekend and I have been noticing the power tailing off when the wmi kicks in. It's not every time but it noticeable. I'm currently running the smallest nozzle and it's only running at half pump on 12psi upwards.
    Apart from that, all is well.
  23. Rosso TT
    Rosso TT Member
    146
    This is an interesting subject to me.
    I fitted my pump in the engine bay on the firewall behind the tip, going to wire up the controller in a couple of days.
    Do you run plain water or w/m mix?
    I'm going to run mine just with water and small nozzle to begin with.
  24. Schlaag
    Schlaag Bwah
    486
    32
    Westy you swine! I've just spent 2.5 hours reading this thread. Was only meant to be a quick 30 on the sofa with the iPad! Great thread!
    Do you sub out your parts man? I've just bought an S3 and need to give it a service and new brakes front and rear!
    keep up the good work dude
    Dave
  25. Jason.s
    2,879
    348
    If you live close to Bedford then i am the parts man. If not then you`ll have to find your own im affraid :p
  26. Schlaag
    Schlaag Bwah
    486
    32
    Aaah thanks Jason. I am down in Kent unfortunately.
    Do people usually stick to OEM audi brake parts? or go elsewhere? std S3 sizes for the time being. Seen some Brembo max discs for the front at £130. Mot sure on pad choice really... rears are easy from ebay at £50 for discs and pads... Fronts I know are more important
    Then there's the oil servicing. Any OEM dealer must haves? (filters i'd imagine)
  27. Reesy
    3,640
    148
    Without wanting to spam westys thread too much, disks are much of a muchness. It's pads that are important. I run pagid discs (ECP have 30% off at the moment) and ferodo pads (i have a set that i dont need also :sign_plug: ) and rbf600 brake fluid.
    Also got servicing parts from ECP, as I don't think that their is anything in the basic service that is better from a dealer then anywhere else..
  28. Westy
    17,443
    1,105
    The AEM kits recommend you dont fit the pumps in the engine bay to protect them from the weather (granted it's better in Aus) and heat.
    I was running just water but have a little meth in there now too.
    Before I did the engine rebuild I was getting a slight power dip when the WMI kicked in but it was difficult to tell whether it was the WMI or the slipping clutch. Now I have a new clutch I'm sure it can only be the WMI. I need to see what's happening on the dyno.
  29. Rosso TT
    Rosso TT Member
    146
    Thanks for the info westy.
    Pump should be ok, is away from heat sources and water splashes.
  30. badger5
    9,559
    2,028
    which nozzle?
    start spray psi later and see
  31. Westy
    17,443
    1,105
    It's the smallest AEM nozzle Bill and I'm currently only bringing in half pump at 12psi which is as late as it will go!
  32. Westy
    17,443
    1,105
    Although very dirty I thought I'd grab a pic of the car with the TT rims on. I don't think it looks too bad:
  33. Dani_B19
    9,343
    394
    Needs some pro race 1.2's on it or some ultraleggera :), looks good though matey.
  34. Westy
    17,443
    1,105
    Got a 2nd hand heatshield from an ASN Mende called V4rley (cheers bud).
    I think it'll help protect the red hose from the XS mani:
  35. Westy
    17,443
    1,105
    That's the plan mate. These wheels are just to tie me over ;)
  36. Westy
    17,443
    1,105
    DP is now sorted :yahoo: no more vibrating.
    Had to use some washers onthe hanging bracket to lift the DP 1mm then use a jubilee clip to pull the DP over to the passenger side slightly. Went out for a drive and it didn't rattle once.
    I didn't have my laptop with me to do any logging but I did try a few blast with wmi plugged and some with the pump unplugged. I can feel the car is slightly hesitant with the wmi running! Very strange.
    I'll drop the oil if I get time this week then I'll do some proper VCDS logging and add a bit more boost and some timing.
  37. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I have spent the last few days reading your thread, amazing effort and a lot of information in it towards this car. Can I ask if you have the part number for that R8 filler cap? I'm going to clean up my rocker cover and would like to add that cap as a finishing touch, thank you.
  38. Westy
    17,443
    1,105
    Thanks mate. A fair amount of cash and effort has gone into the old girl.
    I'm not sure what the part number is as my friendly parts advisor ordered it for me. I'm sure if you google it you'll find an answer as they're quite popular on the VAG scene.
  39. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    the car looks suprisingly awesome on those wheels! i like.
    btw, you left your dv and n75 pipes off the charge pipe. duuhhhhhhhhhhh
  40. Westy
    17,443
    1,105
    Only for the pic you eagle eyed mofo.
    The wheels are real marmite. Got a good 50/50 split on people who like them to people who don't.
