W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    43 vote(s)
    58.1%
  2. Kawasaki Green
    31 vote(s)
    41.9%
  1. Jason.s
    Jason.s Active Member
    2,879
    348
    Picking up your head? Im going to Cylinder head engineering this morning to drop some bits off for a head we have there lol. I`ll be fitting my coilovers on saturday so probably wouldnt be able to meet you up there. Just drop them at St Ives or something and i`ll get them next week :)
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Yes mate collecting the head, finally.
    Ok I'll drop the parts off at St. Ives VW.
    Can anyone advise whether its worth me changing the wrist pins?
  3. aragorn
    18,579
    868
    I didnt bother.
    Unless they look totalled like tufftys were, i dont see any point.
    I've stripped three engines including one that had siezed and one that had done 200k miles and none of them had worn gudgeon pins.
  4. Westy
    17,443
    1,105
    Thanks, that settles it then. They appear to be a pain to order too as they aren't listed as a separate part on ETKA, they come with new pistons. Jason said that he can send some forms to Audi to get them separate but I'll save him the hassle ;)
  5. <tuffty/>
    21,804
    4,172
    Mine were ruined mate but I inspect every engine I do and mine were the first I had seen that bad...
    Be interesting to see how much new pins would be I guess... I have a set of perfectly good S3 pistons but no pins :(
  6. Westy
    17,443
    1,105
    I'm also going to be fitting new engine mounts and wondered if it was advised to replace all the bolts?
  7. Backdraft Motorsport
    Backdraft Motorsport 1.8T & 2.0TFSi Specialists Site Sponsor
    212
    73
    Hi Westy,
    Just had a skim through the thread. Excellent stuff and an interesting read. A real
    labour of love has gone into this. I didn't realise you were the person behind the order! We do usually have stock of the standard IE rods, however the rifle drilled rods are special order. I can assure you we ordered your rods with IE the very same day that you placed the order with us on the 27th of Jan. I can only extend IE's apologies for the delay, but you won’t be disappointed when they arrive.
  8. Westy
    17,443
    1,105
    Thanks for the comments and reassurance Steve. I ordered them nice and early in case there was any kind of delay as I had heard about others waiting long times for rods from IE.
  9. Westy
    17,443
    1,105
    Removed my phenolic gasket tonight so I can start porting one side to match the large port head.
    Here you can see just how much larger I need to port it:
    I also fitted my TFSI coils so it'll be nice to see how they go over the next few weeks.
  10. Westy
    17,443
    1,105
    I collected my refurbed cylinder head on Saturday so here's a few pics:
    Has anyone got any procedures for cleaning a cylinder head before install? There are a few bits of swarf and filings floating about.
    Also when I get this engine all built up is there any running period needed due to the head refurb? Should I use some different oil for running in before filling it with 5w40 platinum?
  11. Westy
    17,443
    1,105
    Anyone? :(
  12. <tuffty/>
    21,804
    4,172
    Haven't got time to post owt until I get home but will throw some stuff together when I do...
  13. <tuffty/>
    21,804
    4,172
    Righty... forgot (as ususal) when I got home last night but...
    Cleaning wise I would pull the followers out (number them if you plan to reuse and I use the suction cup of a valve lapping tool or a blob of blue tac would do as long as you wipe the residue off afterwards) and then rinse through with brake cleaner or clean water from a hose checking for obvious signs of swarf etc... then airline to blow dry or try to remove as much water residue as poss to prevent corrosion... once done spray a light coating of wd40 or similar over the steel components to protect them...
    When you build the head using your cams etc I would advise using an engine assembly lube rather than oil as it sticks better for initial startup and while its sat waiting for it to be fitted... keep the followers out until you are ready to do the build
    If you think the followers in the replacement head are ok then there is no reason not to use them but I would inspect these and the ones on your BAM head to see if either are worn...
    As you are replacing rings and shizzle then I would be tempted to use a mineral or semi synth oil to do the initial running in then dump it for fully synth... I used 10W40 semi synth when I did my rings but I also did some running in on the dyno as well as 400/500 miles on that oil before dumping it and the filter for 5w40 fully synth and a new filter..
    This was me of course... Aragorn ran in his a little while back but his process was a little more involved than how I did mine... rings will need some pressure behind them to run in :)
  14. Westy
    17,443
    1,105
    I'm not doing the rings mate. Hoping that the pistons and rings are in ok shape. Do I still need to run with semi synth oil if I dont do the rings?
    Also, is there any recommended amount of miles I should do to run in the head?
  15. <tuffty/>
    21,804
    4,172
    Ah, ok... no real need to run in a head tbh... if you build with engine assembly lube then I would be tempted to drop the oil sooner rather than later especially if you plan to take to the track...
  16. Westy
    17,443
    1,105
    Cheers for the info mate. Man of your word as always :thumbsup:
    1 last question. What are the signs of wear and tear on the followers? I would like to think that the head place would have mentioned any wear to me when they refurbed it. Also I'd expect my BAM followers would have taken a lot more of a beating then the ones from this Passatt AEB head but you never know.
  17. <tuffty/>
    21,804
    4,172
    They normally wear in the middle... sometimes the case hardening goes and the cams start to dig a groove in the middle... circular 'marks' tend to be fine as the followers will turn around under normal operation... its not a massively common problem tbh and as long as the AEB head was in fairly good shape then I can't see it being an issue... just worth looking anyway to be sure...
    Only other problem is they can go sticky but again if everything looked clean then I can't see a prob... I ended up fitting new ones on mine as I was chasing a rattle that turned out to be the small ends (DOH!)... 2 heads, oil pump and a set of followers that cost me lol...
  18. badger5
    9,578
    2,040
    also check springs are seated..
    rotate head a few times once assembled off the car to be sure all rotates freely and nothing binds etc
  19. Westy
    17,443
    1,105
    So as I'm not doing the rings, how many miles roughly shall I run it on semi synthetic before changing the oil to the good stuff? I'm guessing it'll be good to flush any little bits that have found their way into the oil channels.
  20. <tuffty/>
    21,804
    4,172
    Couple of hundred tops I would imagine... can't remember what I did the first time I changed mine... I think I ran 10w40 for a bit then droppped it but can't remember how long it was in there for..
  21. aragorn
    18,579
    868
    Why arent you doing the rings?
    IMO its a really crappy idea to take it all apart and not replace them for what they cost (about £80 for the set)
    Why on earth would you goto the effort your going to, and distrub everything, then refit some skanky 12 year old rings?
  22. Westy
    17,443
    1,105
    The plan was to only replace them if necessary. I was going to inspect them when I get the pistons out.
    You do have a point and I suppose I should really get new rings considering everything else is being done. I feel reasonably confident with most jobs in this build but gapping the rings isn't one of them.
  23. Prawn
    11,641
    3,636
    Here's a question: If replacing rings should you rehone the bores too? Do you run the risk of glazing by putting fresh rings in a polished worn bore? I was under the impression that the cross hatched honing and new rings ran in together?
    I've built engines before, but always on a fresh rebore with new pistons and rings, I've never changed rings in an existing engine.
  24. Westy
    17,443
    1,105
    Ahh yes, now you've reminded me why I wasn't going to do the rings. I remember seeing a youtube guide and you should hone the bores first.
  25. aragorn
    18,579
    868
    So hone them, its not exactly difficult man!
    I've got a 1.8T sized flexhone you can borrow if you want to use that method.
    When i rebuilt the Sheds motor i had the machine shop hone the bores, but i did the TT engine using the flexhone and the bore finish was pretty much the same.
    I found the slight bore wear on both engines meant the rings didnt need gapped, they were all within spec streight out the packet.
  26. <tuffty/>
    21,804
    4,172
    Yes you should and the link to that set of 'engine build' videos is in my build thread from when I did my rings at christmas...
  27. Westy
    17,443
    1,105
    I may take you up on your offer then. I'm guessing it attaches to a drill?
    Also do these rings look ok?
    eBay - The UK's Online Marketplace
  28. <tuffty/>
    21,804
    4,172
    Oh yeah... and make sure you cover the crank journals so the crud doesn't get on them and watch the oil squirters!!!
  29. Westy
    17,443
    1,105
    It's all just something else to bloody worry about :sadlike:
  30. <tuffty/>
    21,804
    4,172
    While they state they may send Mahle (the OEM make of the VAG pistons) I am still a little dubious about them... tbh... VAG ones may be a safer bet... but they are not the cheapest...
  31. Westy
    17,443
    1,105
    I've been quoted £60 per piston from VW with usual discounts so that's out of the question.
  32. aragorn
    18,579
    868
    I'm using Mahle rings from All German Parts in Shed.
    Its not blown up yet :p
  33. <tuffty/>
    21,804
    4,172
  34. Westy
    17,443
    1,105
  35. aragorn
    18,579
    868
    Link doesnt work :p
    I notice your using Brute rods though :)
  36. Westy
    17,443
    1,105
    I take it back I've already seen that bit in your thread :moa:
    I'll take a punt on those ebay rings then unless I can find them cheaper elsewhere.
  37. aragorn
    18,579
    868
    Give Jason at All German a ring and see what he can do on the price.
  38. <tuffty/>
    21,804
    4,172
    Fixed and yeah... its what Bill had in at the time :)
  39. Jason.s
    2,879
    348
    Now my system is up i can qoute properly lol.
    4 sets inc vat with the usual discount comes to £118.68.
  40. Westy
    17,443
    1,105
    Thanks for checking mate. I'll let you know.
