W3STY's Progress Thread
Westy May 9, 2011
What colour S3 Avus for the Track?
  1. Porsche Guards Red
    42 vote(s)
    58.3%
  2. Kawasaki Green
    30 vote(s)
    41.7%
  1. Broken Byzan
    13,237
    465
    Just to note, let the tyre down to around 15PSI as much more "can" see the resevoir off ( ask me how i know?)
    the important step is the MC ones from experience, they make the largest difference to pedal once the rest are done, as stated by our resident expert above ^^^
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    What tools do I need to reach the MC nipples? I hate brakes, they scare me :(
  3. Broken Byzan
    13,237
    465
    7 or 8mm socket iirc access is limited so catching the fluid in nigh on impossible. I let the fluid eek out and then rinse down the area to make sure the leaked fluid does no damage at all..
    If you get stuck mate, give me a shout.
    ( PS cheers for the birtday wishes too )
  4. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    My master cylinder has always needed doing to get a nice pedal feel.
  5. Westy
    17,443
    1,103
    Yeah but you never bled it yourself! :)
  6. Dane
    4,086
    182
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If you can keep the fluid topped up in the MC you wont need to bleed it...like said get the calipers/pads in place then undo the flexi last and quickly put it onto your new caliper top the mc up then repeat the other side..
  8. Westy
    17,443
    1,103
    Do you mean Resevoir not MC in red??
    The fluid that is in the res currently is RBF600 and it's only a year old. I've bought a litre of RBF660 but is a litre enough to bleed the whole system???
  9. JS1500
    JS1500 Howdy
    1,166
    10
    I think 1.5l is necessary to do the whole system, but i've never done it myself.
    I've bought 3x 500ml bottles of RBF600 the last two times my fluid's been changed and both times i've got back half a bottle to use for top-ups.
  10. s3dave
    10,110
    736
    Yeah sorry the MC Resevoir
    just couldnt spell it....:p
  11. JS1500
    JS1500 Howdy
    1,166
    10
    Reservoir
    :readit:
  12. Westy
    17,443
    1,103
    Ok I'm ready to attack this bad bwoy job tonight :weight_lift2:
    How much fluid should I expect to loose when swapping over the new braided lines? Also should I attach them to the calippers first then to the brake lines or, lines first then connect to the calippers???? :think:
  13. badger5
    9,405
    1,945
    make the fluid connection the very last one.. so hoses on calipers first imho (thats what I do to try an minimise the loss.
    I also crack open the bleeds and allow gravity to fill the calipers initially.. and I think it fills better and eases out the air more naturally.. then use my vacuum bleed to make sure.
  14. Westy
    17,443
    1,103
    Well the pads turned up but I ran into a few issues with fitting so I have done all the prep work ready to fit and bleed on Thursday night.
    First problem was the disc dust shields. The caliper was touching them so I had to get the PCD adapter off and the disc to take them off. Once they were off I then realised that the metal pegs on the calipers will need a little bit of filing down as it was too close for comfort and I think a brand new disc would have caused problems.
    After that I then had to push back the pistons all the way to fit the new pads and hammer in the retaining pin. Anyway here's some nice pics:
    New carrier fitted
  15. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Nicely done that man.
    I'm liking the red.
    Could you not cut the shields to so you can keep them on?
  16. Westy
    17,443
    1,103
    **** the shields man! It was easier to remove than to cut, plus it's weight saving............ which has been made up by the heavier calipers :(
  17. Prawn
    11,423
    3,308
    are the porsche calipers really heavier than the nasty iron **** that's on there at the mo?
    Bad luck on the issues mate. I'm sure they'll be on tomorrow though :)
  18. Westy
    17,443
    1,103
    I'll weigh them mate and let you know.
    Cant do them tomorrow as my gf is coming over so they'll get done on Thursday :yahoo:
  19. OrkneyS3
    OrkneyS3 Member
    66
    9
    Calipers look great bud, ur thread has given me ideas and inspiration, just 2weeks till i get home and get my new baby:thumbsup:
  20. Westy
    17,443
    1,103
    All done :yahoo:
    Ran into a few issues (as always) When I first attached up the braided hoses to the hard brake lines and fluid started to fill the calipers there was a leak from the drivers side bridge pipe. I swapped the old caliper braided hose back and set about taking the bridge line off to investigate the leak.
    The problem was with the powder coating in the thread of the male part, so I had to scrape it out with a blade:
    shakey photos by Tam ;)
    Once the leak was sorted it was time to bleed the feckers. As I hadn't touched the rear brakes and I wasn't doing a full fluid flush I just bled the fronts. I went round them 4 times and got all the air out. There was a slight issue with the drivers side outer nipple being clogged with shot blast from the powder coaters. You can see the little bits of metal in this pic which looks a bit like a lava lamp :)
    Once bled it was wheels back on, quick check for any leaks, and time for a spin:
    Well I expected them to be good, but Jesus they are good. Didn't go too mad as the pads are brand new but they are much sharper for normal town braking, and unbelievable from high speed, I think I gave Tam wiplash :racer:
  21. s3dave
    10,110
    736
    Excellent mate well done..easier than you thought?
  22. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,133
    9,138
    Well done W3sty, looking really smart.
  23. Westy
    17,443
    1,103
    Yes it was. The ezibleed kit is a wicked invention and made the job very easy. I wouldn't want to do a full flush and have to bleed the MC though.
  24. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    looking good mate, look amazing behind the S4's
  25. Westy
    17,443
    1,103
    I think they look a bit small behind the S4s. Imagine them behind some Kowasaki green S3s, shame that wont be happening now :(
  26. ScottD3
    15,161
    1,121
    Nice one mate.
    Knew you could do it.
    Glad you like them and more that they work. :)
  27. damo.h
    3,610
    67
    Na they look good mate
    how come?? you not getting track tyres for the 17's now.
  28. Westy
    17,443
    1,103
    Cheers Scott, you did a blinding job mate, cant thank you enough. Lets see how they fair up at the Nurburgring.
    I'm struggling to find anywhere to store them at the moment without tyres on the let alone once they've got tyres on so they're up for sale :(
    When I have space I'll get myself a cheap set and get them refurbed with track rubber.
  29. Prawn
    11,423
    3,308
    Awesome news dude :) So glad the'yre doing you well!
    WHen you wear these discs out, you can get yourself some MG ZT V8 325mm discs, and space the calipers out 3.5mm to suit :)
  30. Westy
    17,443
    1,103
    Haha nice try. The whole reason for me going for the Boxster calipers was so I could keep using the cheapy small discs :whistle2:
    Am I the only S3 running Boxster calipers :think:, I'm such a trend setter. I wonder if Damo will copy me like he did with the S4 wheels :moa:
  31. damo.h
    3,610
    67
    Baaaaaa.... Na ill just get my 17's refurbed in Kawasaki Green to piss you off :nyah:
    am still tempted to go for some rc's/ ch's.
  32. badger5
    9,405
    1,945
    dont forget to bed it all in progressively dude
  33. Westy
    17,443
    1,103
    I will Bill :yum:
    The discs are a year old and were bedded in using your giuide with DS2500s so they are used to the heat already, all be it not from a 4 piston hammering!
    I've got a 90 mile trip this weekend so I'll be doing some light braking for all of that then I'll run through your guide again next week.
  34. Dane
    4,086
    182
    Looking good dude, welcome to the club ;)
  35. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Still a fair bit of meat on your discs considering there a year old! Will be getting my Brembo Max's fitted tomorrow. (and touch up the red calliper paint!) :)
  36. Westy
    17,443
    1,103
    Shows you how good I am on the brakes.
    These were the pads that came out of the S3 calipers:
    Loads of meat left on them.
    Make sure you do that guide for bedding in your brakes Fran and you'll be fine.
  37. Dane
    4,086
    182
    My fronts are covered in brake dust 90% of the time, the price we pay I guess.
  38. Westy
    17,443
    1,103
    This is why I'm going to get my wheels refurbed in anthracite ;)
  39. Dane
    4,086
    182
    Clever man! Karls looks good like that!
  40. Westy
    17,443
    1,103
    I was never sure about anthracite with the ming blue but seeing Karl's last week has changed my mind.
